BBF Billet Race Head ????????
+9
Gary Blair
Frank Kramer
KEVIN S
kjebba
LivermoreDave
QtrWarrior
twinturrbo406
13 posters
BBF Billet Race Head ???????? Empty BBF Billet Race Head ????????
Post  twinturrbo406 September 30th 2012, 10:42 pm
... ok guys, we are in the process of designing many new billet cylinder-heads, and i propose to you guys some questions ??? ... if a new BBF Billet Race Head were available, what application,deck-height, bore space, valve sizes, C.I. ranges, RPM/piston speed, manifolding, fuel deliveryetc. would be most sought after ??? ... now this would obviously be a fairly exspensive cylinder head, considering its billet, but our price points should be very very nice for this head ...
... obviously, we have design criteria, features and such in mind for what i want to do with the head, but i am basically telling you we want to build a new BBF Billet Race Head, and we want to know what you guys would like, or expect to see ??? ... anything goes here, so lets hear it ??? ... santa
twinturrbo406
twinturrbo406
BBF Billet Race Head ???????? Empty Re: BBF Billet Race Head ????????
Post  dfree383 October 1st 2012, 12:26 am
Cost will be your biggest problem to overcome..... not alot of guys have the $$$ to get a set.
1) Flexible design with 4-5 different intake / exhaust ports for different sized engines with a std location or optional raised locations.
2) Valve sizes from 2.2 to 2.5 for various bore sizes, same with chambers 60-100cc range avaliable.
3) Use readily avalaible exhaust flanges and location to allow reuse of headersguys have.
4) 18 Head Bolts and use a std head gasket.
5) Allow fitment of avaliable cast manifold, A460? C460? Thor?
In other words make the product very flexible and fit the bill for everyone from Pulling Trucks to ProMod at a reasonable price.
Post  c.evans October 1st 2012, 12:39 am
You all might want to wait a few weeks and see what comes out from Edelbrock at the SEMA, PRI, and IMIS shows.
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  QtrWarrior October 1st 2012, 4:21 am
Seems like Charlie knows something !!! Suspect
QtrWarrior
QtrWarrior
Post  dfree383 October 1st 2012, 4:25 am
QtrWarrior wrote:Seems like Charlie knows something !!! Suspect
and he's not Squeeeeeelin'...... Suspect Laughing
Post  LivermoreDave October 1st 2012, 7:29 am
Run his head under the bed ....... he'll squeal! ... Very Happy ...
LivermoreDave
Post  kjebba October 1st 2012, 1:55 pm
I would like to se a billet thor head. Friend here in sweden had his second set cracking in the intake port.
632 turbo build. Seems like it happens to other thor turbo motors in the us allso.
Do you have a number that i can reach you.
kjebba
kjebba
Post  KEVIN S October 1st 2012, 3:01 pm
I would love a billet Thor Gen 2 style head that used all the same hardware. I dont know how quick you will sell these things. It would probably go over better with easily avail. billet blocks too. I think most promod guys go to 5.0 inch stuff turbo or 5.2-3 nitrous to get the billet block and heads,so it might be hard to find a huge market. I do think given quality billets parts that are easily available some would chose to stick with BBF stuff especially if they have already been running them and stepping up to faster classes. I would go post over at yellowbullet.com there are some max effort guys over there that are not on this site. KS
KEVIN S
Post  Frank Kramer October 1st 2012, 4:35 pm
twinturrbo406 wrote:... ok guys, we are in the process of designing many new billet cylinder-heads, and i propose to you guys some questions ??? ... if a new BBF Billet Race Head were available, what application,deck-height, bore space, valve sizes, C.I. ranges, RPM/piston speed, manifolding, fuel deliveryetc. would be most sought after ??? ... now this would obviously be a fairly exspensive cylinder head, considering its billet, but our price points should be very very nice for this head ...
Probaly something like the AJPE muscle head or the Noonan X1 head. Don't forget that you need a billet lightweight block with external oil pump also....
Frank Kramer
Frank Kramer
http://www.seasideaffair.com
Post  Gary Blair October 1st 2012, 7:37 pm
Dr. Rick has a few suprises Very Happy
Gary Blair
Gary Blair
Post  dfree383 October 1st 2012, 10:32 pm
Gary Blair wrote:Dr. Rick has a few suprises Very Happy
Ahhhhh OK......now Im in tune!
Post  Paul Kane October 2nd 2012, 12:12 pm
Guys, I think the question is geared more toward serious max effort billet heads. There is nothing "sportsman" about creating a billet sportsman head. Besides, 95% of the field would be left out because they could not afford to run them.
There is no need to make a solid billet Thor head. If you are making over 3000 hp and want to use a Thor head then you can just fill a Thor head solid, and for a lot less cost.
3-4 years ago, I met a guy working on an overhead cam 385 Series head. I don't know the status of that project. I think it was a 3-valve head. By the way, I've thought about a 3-valve design for our head but it would further limit the classes where such a head is allowed. Nevertheless, it's a very easy feature to add to the current design.
I think Kramer's understands the question the best.
Paul
P.S.: Given that the NHRA is essentially sinking slowly and not helping Ford I continue to hang onto a thread that someone like Force will end up with the NHRA and/or fund it provided they allow Ford-derived engines to run again.
Post  kjebba October 2nd 2012, 5:20 pm
Allready broke two sets that had waterjacks filled. And what i hear we are not the only ones whit this problem on the Thor head and turbo. The Thor heads are some nice castings but seams like this engine have past the point for what cylinderheads with waterjackets can take.
kjebba
kjebba
Post  maverick October 2nd 2012, 7:40 pm
P.S.: Given that the NHRA is essentially sinking slowly and not helping Ford I continue to hang onto a thread that someone like Force will end up with the NHRA and/or fund it provided they allow Ford-derived engines to run again. [/quote]
I don't think NHRA is sinking...I believe we're watching a slow suicide, just like NASCAR
Post  Paul Kane October 3rd 2012, 11:31 am
kjebba wrote:Already broke two sets that had waterjackets filled. And what i hear we are not the only ones whit this problem on the Thor head and turbo. The Thor heads are some nice castings but seems like this engine have past the point for what cylinder heads with waterjackets can take.
You "broke" two filled sets of Thors? Or do you only mean to say that they are simply cracking (as you noted above)? Can't you just weld up the cracks? Also, I'm curious what you are using for water jacket filler.
In my post above, I was thinking more along the lines of solid billet or jacket filler so as to not blow them completely apart. Cracking is certainly something to consider.
Also, it may be possible that the Thor can be cast without the jacket core in the mold (ie, cast as a solid head).
Paul
Heh-heh. Laughing
Post  Paul Kane October 3rd 2012, 11:34 am
c.evans wrote:You all might want to wait a few weeks and see what comes out from Edelbrock at the SEMA, PRI, and IMIS shows.
Charlie
I just got a glimpse of the BBC application. Nice. Cool
Post  c.evans October 3rd 2012, 5:14 pm
kjebba wrote:Allready broke two sets that had waterjacks filled. And what i hear we are not the only ones whit this problem on the Thor head and turbo. The Thor heads are some nice castings but seams like this engine have past the point for what cylinderheads with waterjackets can take.
kjebba,
I do not know whether or not you are aware of the fact that the Pro-Filer 205 big block Ford heads are available WITHOUT water jackets. Here is link; http://www.profilerperformance.com/racing/cylinderheads/bbfheads
Hope this helps,
Charlie Evans
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  Gary Blair October 3rd 2012, 8:59 pm
Charlie
Wink
Gary Blair
Gary Blair
Post  rmcomprandy October 3rd 2012, 10:39 pm
Maybe I am alone here but, I would like to see a billet head like the newest "hedge" Pro-Stock FRPP head but, with the intake port entrances and flange changed slightly so a Blue Thunder "Thor" cast intake manifold would fit.
Post  twinturrbo406 October 4th 2012, 2:48 am
rmcomprandy wrote:Maybe I am alone here but, I would like to see a billet head like the newest "hedge" Pro-Stock FRPP head but, with the intake port entrances and flange changed slightly so a Blue Thunder "Thor" cast intake manifold would fit.
... now your talkin', i kinda' had something like that in mind, at least one idea anyways ...
... i have seen the 2pc. Blue Thunder SBF manifold, what does the THOR intake look like ?? i didn't see it on Survival's website ??? ... No
twinturrbo406
twinturrbo406
Post  c.evans October 4th 2012, 3:29 am
The Thor intake is again a 2 piece intake, divided in half. It also has a seperate valley plate, so I guess we can call it a 3 piece. If this link works, it is the bottom picture on the first page. http://www.460ford.com/forum/showthread.php?t=116283&highlight=winter+tech+seminar
Hope this helps,
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  the Coug October 4th 2012, 4:09 pm
The only Problem I see with a solid billit head is that it is a pretty small client list, where if you built a wet head that would work for most racers it would have a much bigger client list and more uses.....JMHO
Post  Frank Kramer October 4th 2012, 4:40 pm
Take a look at bamberengineering.com and look at their billet hemi head
But for what application do you want to make that head? For blown alcohol like tractor pulling and promod drag racing it really has to be a hemi.
Frank Kramer
Frank Kramer
Post  twinturrbo406 October 7th 2012, 1:12 pm
... its looking like the Hemi is a popular vote so far ?? ... Very Happy
twinturrbo406
twinturrbo406
