Solid roller for 460 225 shipped in the 48
Solid roller for 460 225 shipped in the 48 Empty Solid roller for 460 225 shipped in the 48
Post  shelby_67 October 18th 2012, 11:06 am
Comp solid roller has double dowl good condition
CAm card below
Serial # S 4158-10 Spec Card# 17543010
Part # 34-000-9 CAMSHAFT, FF FORD 429-460 ROLLER
Core C34-9A CAMSHAFT BLANK, FF FORD 429-460, 5160
Grind # FF 2233F /4075F SR112.0
DURATION @ .050 INTAKE 274 ROCKER ARM RATIO
VALVE ADJ INTAKE .016 DURATION @ .050 EXHAUST 289 INTAKE 1.73
VALVE ADJ EXHAUST .018 LOBE LIFT INTAKE .4550 EXHAUST 1.73
VALVE LIFT INTAKE .787 LOBE LIFT EXHAUST .4600
VALVE LIFT EXHAUST .795 LOBE SEPARATION 112.0
DURATION .020 INTAKE C/L 112.0
TAPPET LIFT INTAKE 303 CAM ADVANCE 0
TAPPET LIFT EXHAUST 323 HYDRAULIC
VALVE TIMING .050 OVERHEAD CAM N
VALVE OPEN INTAKE 25 JOURNAL DIAMETER STD 2.124
VALVE OPEN EXHAUST 76 RECOMMENDED VALVE SPRINGS
VALVE CLOSED INTAKE 69 DEPARTMENT P
VALVE CLOSED EXHAUST 32 SPC INSTR FOR CUSTOMER
shelby_67
