Extreme stroker kit.....
Have any of you guys seen this setup. What would you use a stroke like this for? I'd bet that thing will shredded some weak parts that are hooked up to it.
Pretty cool...
X-Treme Mountain Motor Kit
Big Block Ford 460
Our X-Treme Mountain Kits include:•Billet 4.650 stroke Crank
•H-Beam Rods
•Forged Pistons (available in different bores and compression).
- These kits will fit into a BBF STOCK 460 block with ANY bore.
- Cranks have center counterweights and have a 302 small snout.
You will have a MASSIVE 577 cubes with a STOCK block, creating torque to pull down a building, and the Horse power to boot!!!
(Aftermarket blocks with larger bores get up to 633 inches!)
Part #: XTREME-MM-KIT
Prices: Complete kits start at only $3569………
(A billet crank available anywhere else is $2900 alone - which makes this kit an unbelievable deal!!!!!!)
Customize YOUR Kit: You get the crank, rods and forged pistons in your Kit already, customize it for even more power easily by adding one or more of our many upgrades available for your engine to this kit… just give us a call!
That is a Flatlander Racing mountain kit.
Pretty cool...
Big Block Ford 460
•H-Beam Rods
Re: Extreme stroker kit.....
Billet SCAT can get bigger
dfree383 wrote:Billet SCAT can get bigger
True. But with a stock block and that stroke I'd bet it would be a piston scuffing SOB. Nothing wrong with the SCAT billet in my book, I bought a mid weight SCAT BILLET one ( 3 grades at the time, standard, lightweight, and super light) 8-9 years ago amd it was a tad over $2400 then.
» pro extreme
» 15,000 to win FTI Extreme !!!
» stroker kit
» Comp Cams Extreme Energy 270 4X4 Cam
» VAVLE HEIGHT SETUP RANGE FOPR OEM dove 429 HEADS
» stroker kit
