timing chain cover
timing chain cover
I had to buy a timing cover for the 429 I am working on and the one I got has a provision for a dip stick. Since the oil dip stick for this motor is in the oil pan I do not need the one in the timing cover. Now the timing cover came with a 3 inch rod to be inserted into the hole where the dip stick goes. So my question is, how far down does this rod have to go? This is a Ford Motorsport timing cover and there are 3 holes that this rod has to go through, the third one being the one that leads to the oil supply.
motorhead- Posts : 75
Re: timing chain cover
As I recall, I usually install the plug so it is left slightly protruding from the top of the cover.
It really makes no difference as long as the hole is filled.
I always put Loctite on the plug to seal it before pressing it in.
motorhead wrote:I had to buy a timing cover for the 429 I am working on and the one I got has a provision for a dip stick. Since the oil dip stick for this motor is in the oil pan I do not need the one in the timing cover. Now the timing cover came with a 3 inch rod to be inserted into the hole where the dip stick goes. So my question is, how far down does this rod have to go? This is a Ford Motorsport timing cover and there are 3 holes that this rod has to go through, the third one being the one that leads to the oil supply.
The largest diameter, (about 5/8" long), is above the top casting.
on my stock cover i squeezed the end of the tube tight with a pair of side cutters and brazed it.....bobn
zbob- Posts : 271
zbob wrote:on my stock cover i squeezed the end of the tube tight with a pair of side cutters and brazed it.....bobn
I cut the dip stick off about 3'' from the top filled the cup up under the pull ring with RTV and put it back in
» Timing chain help
» wtb timing chain cover
» does anyone make a billet timing chain cover
» Advance Cam or Not ?
» Timing chain stretch
