Super Duty blowing fuses
NOS42
Super Duty blowing fuses Empty Super Duty blowing fuses
Post  maverick November 13th 2012, 4:47 pm
Do any of you guys know what would cause my 2003 to blow the #17 fuse in the panel under the steering column? After driving for hours on Sunday night, my instrument cluster lights suddenly went out. Upon checkng, I found that I also had no running lights or marker lights. After replacing the fuse, the lights may work for several seconds, maybe a minute, then the fuse blows. Because this takes time to heat up and blow, a slightly higher amp fuse might keep things working, but I know that's just begging for an electrical fire.
I've checked (and disconnected) the trailer wiring plug and all 4 corner lamps are working until the fuse blows. Could this be some sort of relay problem?
Super Duty blowing fuses Empty Re: Super Duty blowing fuses
Post  maverick November 14th 2012, 4:44 am
up
Post  NOS42 November 14th 2012, 4:24 pm
Most likely the shifter handle on the column....overdrive button wires rub causing this issue....easy repair
NOS42
NOS42
Post  maverick November 14th 2012, 5:31 pm
Thanks much. I'll check that out.
Post  maverick November 15th 2012, 9:47 am
NOS42, you have a pm.
Post  NOS42 November 15th 2012, 10:19 am
Back at ya
NOS42
NOS42
Post  maverick November 15th 2012, 11:20 am
You da man! cheers
Post  NOS42 November 15th 2012, 12:08 pm
Glad I could help......Mike
NOS42
NOS42
Post  IDT-572 November 15th 2012, 12:12 pm
maverick wrote:Do any of you guys know what would cause my 2003 to blow the #17 fuse in the panel under the steering column? After driving for hours on Sunday night, my instrument cluster lights suddenly went out. Upon checkng, I found that I also had no running lights or marker lights. After replacing the fuse, the lights may work for several seconds, maybe a minute, then the fuse blows. Because this takes time to heat up and blow, a slightly higher amp fuse might keep things working, but I know that's just begging for an electrical fire.
Using a larger fuse on a faulted circuit is called a smoke test and is widely used in home garage settings and driveways. It usually finds the short but also usually with costly results.
I don't recommend this test , but have used it on occasion when temper over rode better judgement. Cool
Post  NOS42 November 15th 2012, 12:16 pm
All repaired....no smoke test needed...lol
NOS42
NOS42
Post  IDT-572 November 15th 2012, 12:18 pm
NOS42 wrote:All repaired....no smoke test needed...lol
Glad to hear, Idea Wink What did you find?
Post  maverick November 15th 2012, 12:40 pm
Damnedest thing I ever saw. A seemingly unrelated system causing the problem. The wiring in the steering coluumn that runs to the "tow/haul" switch at the end of the shifter was slightly chafed...I mean SLIGHTLY. It would blow the light system fuse but the "tow/haul" would continue to work normally. I'd have NEVER found that one on my own. To NOS42....A public "HATS OFF". cheers
Post  69F100 November 15th 2012, 4:48 pm
I have also used this test ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Mad
Post  Frank Merkl November 15th 2012, 8:17 pm
back when I worked on the bench another tech used that method to find a short in a New "86 Cadillac , I ended up with it after he got run off and I had the privilage of replacing the body harness!!
Post  maverick November 15th 2012, 8:26 pm
Frank Merkl wrote:back when I worked on the bench another tech used that method to find a short in a New "86 Cadillac , I ended up with it after he got run off and I had the privilage of replacing the body harness!!
So the method really works! It pinpointed that bad harness. Laughing Laughing
Post  Frank Merkl November 15th 2012, 8:43 pm
not really a bad harness but a miss aligned harness in the drivers side sill cover and a screw had rubbed a wire , shouldn't have been that hard to find without melting the whole harness !! He took a piece of 10 gauge wire from the batt and plugged into a 22 guage wire and let it smoke!!
Post  schmitty November 15th 2012, 9:48 pm
Frank Merkl wrote:not really a bad harness but a miss aligned harness in the drivers side sill cover and a screw had rubbed a wire , shouldn't have been that hard to find without melting the whole harness !! He took a piece of 10 gauge wire from the batt and plugged into a 22 guage wire and let it smoke!!
Kind of like using a payloader bucket to finish drywall. It gets the job done, but you just have to replace a little more than what you needed to. Laughing
