Epoxy in a C6 valve body -- sound weird?
Paul-uk
whitefield
Greg_P
Has anyone ever seen a C6 valve body that was built using epoxy in the fluid channels?
Sounds weird, but true. Is this something that high end trans shops do, or am I looking at something that is home made?
Greg
Greg
Greg_P- Posts : 1009
Re: Epoxy in a C6 valve body -- sound weird?
I've seen alum plugs, never epoxy.
Doesn't Frank Merkl recommend epoxy for the crappy TCI transbrake cure? Or is my memory going again.
Paul-uk- Posts : 28
On the AOD's there is a relatively common "Epoxy Mod" that they do to modify it.
You can see it in detail on clickclickracing.com website, along with some other great tech.
http://www.clickclickracing.com/forums/showthread.php?t=2817
windsor- Posts : 1167
Paul-uk wrote:Doesn't Frank Merkl recommend epoxy for the crappy TCI transbrake cure? Or is my memory going again.
I think you're right.
Diggindeeper- Posts : 800
JB weld works great for rechanneling valvebodies , proof in point is that the 1st transbrake vb that I ever built is still in my 7sec 186mph racecar and the vb was built in 1991! and I use alot of JB weld with a properly prepared base metal it will never separate
Frank Merkl- Posts : 1524
Forgot I seen the JB weld in one of Franks VB's...........
That JB Weld is some good stuff.
When I was a kid, one of my buddies used it to resurface his fiber discs in his clutch!
This was on a Suzuki RM 125. And you guys know how hard those were run!
Im not joking! Granted he had to re-do it,every few races.
Sorry for the hi-jack.
72mav- Posts : 1081
Marine-tex is another mean item like jb weld.
nuclearcobra- BBF CONTRIBUTOR
» C-4 valve body
» valve body question
» Old Art Carr valve body
» Valve Body C6
» Need a good v/b for C6 prefer Merkyl
» Valve Body C6
