Will a manual block plate from a 77 bronco fit a 71 429 thunderjet block?
stang98kjg- Posts : 3
Re: Will a manual block plate from a 77 bronco fit a 71 429 thunderjet block?
all long as its a 351m or 400,and you use the same bellhousing, yes
BOSS 429- Posts : 2371
You may need to make the center hole bigger to fit over the crankshaft flange.
72puller- Posts : 105
another question
[b]I also meant to ask if the transmission bellhousing from the 77 bronco would work on a 429 mustang.
No. The 77 Bronco was the last of the small Broncos, as far as I know the 302 was the biggest engine available.
AZFairlane- BBF CONTRIBUTOR
AZFairlane wrote:No. The 77 Bronco was the last of the small Broncos, as far as I know the 302 was the biggest engine available.
Yes, 200 six and 302 V-8.
466cj- Posts : 391
THATS WHY I SAID 351M 400 ONLY
Yes, that's why I said the largest engine in a 77 was a 302, because they never put 351M's or 400's in a 77
Let me clarify a bit
I have a 429 engine that came out of a 70 T-Bird in a 1971 Mach 1. It had a C9 automatic on it, but I wanted to change it out to a 4 speed toploader. I ran across a bellhousing that is supposed to fit the 429 that I have but the part number is D7TA7505AD. Someone told me it was a 77 bronco, but that might be wrong. I would appreciate any help. I could get. I have a 429 blockplate coming, but I need a clutch and a throwout bearing. also have the flywheel, the zbar and the clutch/brake combination pedal set. What i'm really concerned with is that bellhousing going to let me hook everything up to the engine.
That bellhousing is for a 351M/400. It will bolt up to your 429. If I recall right best to use a 390 flywheel, 11 inch clutch, and a 351M starter. Boss 429 will know exactly what you need.
466cj- Posts : 391
» WTB manual transmission block plate.
» 429 is Bellhousing plate needed - Manual Tran
» ISO blow proof bellhousing/backing plate to mate a 460 to a manual transmission.
» 460 to C6 block plate
» c6 block plate
» c6 block plate
