BBF in a 64 falcon
BBF in a 64 falcon
Got a friend that is looking a 64 falcon with no engine or transmisson. What would it take to put a 460 in it?
He has already has a 460 with a C6 and a 9 inch, but they will need gone through.
Re: BBF in a 64 falcon
Mustang11 suspension and he's good to go. Can be done w/stock susp. and cutback towers,but it's just not worth it imo.
https://www.429-460.com/t4689-1965-falcon-bbf-build-up-long-term
Here is the crites deal. http://www.tiptopwebsite.com/websites/index2.php?username=colson43&page=11
jasonf- BBF CONTRIBUTOR
Jason,
Is that a pic of your car? Did your UCA get moved out board? I did something similar in my 66 coupe. I kept the stock location (as far as distance between UCAs). However I used the Chassis works UCAS that are designed with a shelby drop into them. Instead of putting in the same location I flipped the UCA mount and put the holes below. This way I got the 1" drop and my bolt holes are 2" lower than the stock location (more header clearance). I am running a 434W, though; wish I had a BBF in the car.
Andrew
Andrew
mtacqua- Posts : 67
No they are not. I just posted a picture from the link I had attached. I'm going to just cut mine out and replace the front end.
» Let's see your ride(s)
» A little Help!
» Thank you for your donation Falcon Eh.
» 1963 Falcon chassis car, Turn Key
» Just another Falcon
» A little Help!
