#1 cylinder no oil 351?
nitro717
I have a friend having issues with his #1 cylinder not getting oil to the rocker arms. It has chewed up a couple sets so far. What would be a good place to look for the problem?
nitro717- Posts : 92
Re: #1 cylinder no oil 351?
sounds like the passage to the lifters on number 1 is stopped up or 2 flat lifters
Check for trash/sludge plugging the pushrods...easy first step.
maverick- BBF CONTRIBUTOR
X2,yes check the pr too see if it is damaged and has closed off hole.
Is oil pressure reading a bit low?
Has the engine recently been assembled?
Has the problem existed since rebuilt?
Is the oil galley plug (lifter galley) in the timing chain area loose or out?
Is the lifter correct?
Dave.
Dave.
LivermoreDave- Posts : 972
The lifters on the #1 cylinder are almost the FIRST place in the engine to get oil, (right after the number 1 cam bearing and about the same time as the number 1 main bearing). So, if you have oil at other places then it is restricted somewhere between the lifter oil hole entry and the rocker arm.
a Cleveland ..Yesrmcomprandy wrote:The lifters on the #1 cylinder are almost the FIRST place in the engine to get oil, (right after the number 1 cam bearing and about the same time as the number 1 main bearing). So, if you have oil at other places then it is restricted somewhere between the lifter oil hole entry and the rocker arm.
351W .NO , last to get oil
DanH- Posts : 1081
Thanks guys, I will relay the info for him!
» 4 cylinder t-5
» What does a-429 or a-460 mean regarding cylinder heads?
» New cylinder heads
» Anybody ever fool with a 300 six cylinder?
» rpm vs cylinder pressure
