552 p-51
+8
2fox
Gary Blair
larry552
12 posters
Page 1 of 3 1, 2, 3  Next
552 p-51 Empty 552 p-51
Post  larry552 December 10th 2012, 2:43 pm
Hello im new to to the site. Im building a flat top 552 with p51 @ 14.1 with a motorsports intake. Im going to have my heads shaved about 30ths. My cam will be 824/792 &285/292 @ 50 on a 112. With about 250-300 on a fogger. My car is stock suspension and is 2860 with me in it on a 28 in tire 3:73 gear 9 inch with a glide. Hopeing to run 5.20-5.30 with this set up. The car went 5.45@131 with my 521 motor. If you guys can help in any way let me know what i need to do different with the new build
larry552
larry552
552 p-51 Empty Re: 552 p-51
Post  Lem Evans December 10th 2012, 3:26 pm
larry552 wrote:Hello im new to to the site. Im building a flat top 552 with p51 @ 14.1 with a motorsports intake. Im going to have my heads shaved about 30ths. My cam will be 824/792 &285/292 @ 50 on a 112. With about 250-300 on a fogger. My car is stock suspension and is 2860 with me in it on a 28 in tire 3:73 gear 9 inch with a glide. Hopeing to run 5.20-5.30 with this set up. The car went 5.45@131 with my 521 motor. If you guys can help in any way let me know what i need to do different with the new build
I.m.o. i'd run more than the 7* split between the int. and exh. duration and a wider lsa.
Post  IDT-572 December 10th 2012, 3:30 pm
X2 even with out the spray it needs more split.
Post  larry552 December 10th 2012, 3:33 pm
Tell me why because i had the cam in the 521 it was 285/300@50 on a 114. The cam man at bullet told me that i was going to have to hit with about 500 on the fogger and i dont want to hit it that hard. This is the same cam out of the 521 just regrinding it
larry552
larry552
Post  larry552 December 10th 2012, 3:37 pm
Lem what u think i should try
larry552
larry552
Post  Lem Evans December 10th 2012, 3:39 pm
Why? Because that's what works Smile
Post  Lem Evans December 10th 2012, 3:44 pm
larry552 wrote:Lem what u think i should try
That 285/300 on 114 lsa gotta be close.
Post  larry552 December 10th 2012, 3:45 pm
What cam profile do i need to run do i need to regrind that cam or just let him send it back.
larry552
larry552
Post  larry552 December 10th 2012, 3:46 pm
Well tell me this wont the 112 give a little more bottom end
larry552
larry552
Post  richter69 December 10th 2012, 3:46 pm
larry552 wrote:Tell me why because i had the cam in the 521 it was 285/300@50 on a 114. The cam man at bullet told me that i was going to have to hit with about 500 on the fogger and i dont want to hit it that hard. This is the same cam out of the 521 just regrinding it
put this cam back in, and if you have to spray more than 150 to get to your goal you got other issues.
Post  Lem Evans December 10th 2012, 3:47 pm
Is the cam damaged?
Post  richter69 December 10th 2012, 3:48 pm
that gut at bullet must grind a lot of bbc cams lol.
Post  larry552 December 10th 2012, 3:51 pm
No cam is fine i slung a rod in the old combination and just wanted to have it checked and i wanted to run more on the motor hoping to run 5.80 or so and then spray it with about 250 and get to that 5.20 goal
larry552
larry552
Post  Lem Evans December 10th 2012, 3:52 pm
larry552 wrote:Well tell me this wont the 112 give a little more bottom end
You put the 'bottom end' in it when you moved up to the 4.500" crankshaft.
The cam that was in the 521" is a better fit in the 545".......more cubes and compression.
Post  larry552 December 10th 2012, 3:53 pm
He always done all of our cams and they have done good except for this set up to me
larry552
larry552
Post  richter69 December 10th 2012, 3:54 pm
I spray 200 in an IS plate and run 5 teens @ almost 3100#s. 563 worked p51s and damn near the same cam as the 114 deal......and thats leavin soft or I kill the oil pan and front suspension on re entry.
Post  Lem Evans December 10th 2012, 3:58 pm
richter69 wrote:I spray 200 in an IS plate and run 5 teens @ almost 3100#s. 563 worked p51s and damn near the same cam as the 114 deal......and thats leavin soft or I kill the oil pan and front suspension on re entry.
Magic "Lem" cam Laughing
Post  larry552 December 10th 2012, 3:59 pm
Well i can understand that then Lem thanks. So do you think i can cut back to the 112 and leave the duration at 50 where its at would help more on the motor
larry552
larry552
Post  larry552 December 10th 2012, 4:02 pm
Ok that car is flying what tire size
larry552
larry552
Post  richter69 December 10th 2012, 4:03 pm
13" lol.
Post  Lem Evans December 10th 2012, 4:06 pm
Who knows what's perfect but, aint no way I'd run tighter than 113*. With the spray I'm still thinking 114*
Having said that ...there can be a lot of difference in lobes with the same @.050" #s. The @.020" and @.200" #s can very much effect the tq. curve of an engine.
Post  richter69 December 10th 2012, 4:09 pm
again if that 114 cam aint hurt put it back in and run it...................and youll need the small jets and I understand the tire deal, but if the tracks good I dont see it being an issue.
Post  larry552 December 10th 2012, 4:30 pm
Well do i need to advance it any or just put it in straight up
larry552
larry552
Post  larry552 December 10th 2012, 4:35 pm
I do have an eldebrock progressive and i think im going to install a 7531. What kind of e.t do yall think this new set up should run
larry552
larry552
Post  IDT-572 December 10th 2012, 4:38 pm
I couldn't even think of running mine with out the progressive, it went 1.18 the other weekend on the motor alone.............. Put your cam in at 112 to start, if you use the 114 cam it will be close.
