Jegs fuel pump
Jegs fuel pump
Will a jegs 130 fuel pump crank a 975hp motor and it run and idle good? This would b the first time firing for this motor.
tconnection- Posts : 866
Re: Jegs fuel pump
thas a good size pump it should run that run fine. i dont think i would use it for performance but may work aswell. i seen a holley black on a 1000hp dyno pull
quick 52- Posts : 612
Re: Jegs fuel pump
quick 52 wrote:thas a good size pump it should run that run fine. i dont think i would use it for performance but may work aswell. i seen a holley black on a 1000hp dyno pull
Dyno pulling is a whole lot different than moving fuel in an accelerating car.
And to answer to OPs question, look at a better pump, that particular pump is too small for a real 975hp application.
Re: Jegs fuel pump
just and answer to the op question he ask if it would run it and idle. and was told i dont think I would use it for performance and that i seen a holley on a 1000hp DYNO PULL. if your just driving and cruising with that pump it will work and will idledfree383 wrote:quick 52 wrote:thas a good size pump it should run that run fine. i dont think i would use it for performance but may work aswell. i seen a holley black on a 1000hp dyno pull
Re: Jegs fuel pump
Im not trying to get to the track no time soon. This is a brand new motor inside and out and has spent alot of money on it. At this point im wanting to keep money spent to a min till everything wiyh the motor checks out and till i get ready to go to the track.
» Do I need to remove my already intalled fuel pump eccentric if I'm now going to be using an electric fuel pump?
» 16 gallon Jegs Pro-street fuel cell with mounting brackets $100+shipping
» Fuel Inj. Pump - Ron's Black Gear Pump - Size "0" - SOLD !!
» Fuel Pump Q
» BG 400 fuel pump help
» Fuel Pump Q
