How fast u think?
How fast u think? Empty How fast u think?
Post  clodracer2000 December 18th 2012, 10:03 pm
Hi dudes! Ive been workin on a project of mine and i was just curious of about how fast in the 1/4 it should run.I should have it complete by feb, heres what i got.........................1970 429 with std bore cj forged pistons, dove-c heads, 3 angle valve job, dual valve springs that match the lunati voodoo cam 582/600lift 284/292 duration, offenhouser port o sonic intake, stock crank, h beam rods, has stock oil pump but im gunna put a high volume pump with a 7 quart oil pan, and hooker 2"headers. Built c6 with 3500 converter.
Car is a 85 notch with UPR adjustable upper and lower rear control arms, strange front and rear adjustable shocks, rear coil overs, front 175lb springs, eaton posi with 355 gears, strange 28spline axles, subframe connectors, and hoosier 275 60 15 drag radials. Full interior except no radio,speakers, or center console.
So let me know what u guys think and im alllllll ears for any pointers u have, thanks!
clodracer2000
How fast u think? Empty Re: How fast u think?
Post  clodracer2000 December 18th 2012, 11:48 pm
Also what's anyone's take on the high volume pump vs a stock oil pump for the set up I have. What a Face
clodracer2000
Post  4thHorseman December 19th 2012, 4:02 pm
I say mid 12's if its dialed right in tune-wise and it hooks right up. It sounds like a well coordinated build but it is pretty mild. Fun street car/ weekend warrior.
More oil is never a bad thing (unless you're puming it all upstairs at once). A better pan and pump can even be worth a few ponies.
4thHorseman
4thHorseman
Post  clodracer2000 December 19th 2012, 7:55 pm
Its def gunna be faster then that, my buddy has a 90 notch with a stock 429 and he went 12.03. He just got intake, good carb, 2800 stall, and nice suspenion. I believe it should run 11.0 to 11.30 range once dialed in good, but i to see what you guys think Smile
clodracer2000
Post  richter69 December 19th 2012, 8:25 pm
The first BBF I had in the 69 is real similar, except it was a 460. 3300#s......it ran 12.0s............
stock pump is fine.....
