Spark plugs for a460 heads
Which plug for n/a 14;1cr 580ci a460 headed motor?
tconnection- Posts : 866
Re: Spark plugs for a460 heads
Or an Autolite AR-3934
Charlie
Charlie
c.evans- BBF VENDOR SPONSOR
Thanks alot men. Im bout ready to put some fuel and spark to it.
i GOT THE NGK-8. What gap should i go with?
what ignition system? What compression? What type of fuel.
Ideally, the widest gap you can without having spark blow out.
That said, with 18-1 compression, MSD 7al-3 and propower coil, anything larger .026 and I have a hard time keeping em sparking.
kim- Posts : 700
kim wrote:what ignition system? What compression? What type of fuel.
Hmmmnnn,,,,with 18:1 compression you don't need a spark plug. They're a diesel
Charlie
Luckly the cam is so long in duration, cranking compression is pitiful, and without at least 20 degrees advance, it wont even start.
Locked out at 32 on alcohol, or 34 on gas, it does it just fine.
If I ever do over, lots of things will be differnt.
kim- Posts : 700
Comp., 14:1, ignition is a crane hi6, msd distributor, i guess 114 octane. And would this hi6 be ok to just start the engine up and seat the rings?
tconnection wrote:Comp., 14:1, ignition is a crane hi6, msd distributor, i guess 114 octane. And would this hi6 be ok to just start the engine up and seat the rings?
Heck yes!
Charlie
Set the gap at .028"ish and go have fun
CHECK!
» A460 spark plugs
» Spark plugs for Dove heads on methanol
» heads with raised exhaust port question? also what spark plugs to run?
» spark plugs and e85
» P 51 spark plugs
» P 51 spark plugs
