P 51 spark plugs
P 51 spark plugs Empty P 51 spark plugs
Post  Larry Williams January 23rd 2016, 11:10 am
What plug should I use with P51 heads?   heads as out of the box
flat top pistons   .010 in the hole       solid roller and a 1400 sv1 carb
14.5 to 1 comp ratio 545 cid
Larry Williams
Larry Williams
P 51 spark plugs Empty Re: P 51 spark plugs
Post  rmcomprandy January 23rd 2016, 12:08 pm
Larry Williams wrote:What plug should I use with P51 heads?   heads as out of the box
How is this engine to be used and does it have a closed exhaust system...?
I would probably use a #3910 Autolite with that compression ratio.
Post  Larry Williams January 23rd 2016, 2:01 pm
a drag only engine with 2" headers
Larry Williams
Larry Williams
Post  Rickytx630 January 23rd 2016, 7:02 pm
have a 514. 15:1 compression. p51 heads, qtf 1250 worked over. use autolite AR3933 plus, no problems. bracket car.
Rickytx630
Post  Larry Williams January 23rd 2016, 7:21 pm
Rickytx630 wrote:have a 514. 15:1 compression. p51 heads, qtf 1250 worked over. use autolite AR3933 plus, no problems. bracket car.
I have lots of those ty
Larry Williams
Larry Williams
Post  rmcomprandy January 23rd 2016, 10:08 pm
A 514 at 15/1 will have a domed piston ... not a flat-top.
One plug is an extended tip and the other is not.
It will be a personal choice.
Post  Larry Williams January 23rd 2016, 11:25 pm
rmcomprandy wrote:A 514 at 15/1 will have a domed piston ... not a flat-top.
is the 3910 an extended tip? Would it be ok to break in the motor with 3932/3933 then go with the 3910x ?
Larry Williams
Larry Williams
Post  rmcomprandy January 24th 2016, 12:50 pm
Yes ... I personally would use a hotter "street type" plug for initial running. Something like a 3924.
Post  Larry Williams January 24th 2016, 5:33 pm
I have a few sets of those too. I have to order the 3910's thanks for the info
Larry Williams
Larry Williams
Post  Rickytx630 January 30th 2016, 12:30 pm
JE flat tops. no domes in my motors.
Rickytx630
Post  rmcomprandy January 30th 2016, 1:50 pm
A 514 with a flat-top piston at "0" deck, #1018 head gasket and a 70cc combustion chamber is about 13.4/1 compression ratio.
The heads would need to be milled near 60 cc's to be at 15/1 compression.
Your personal choice is to use non-extended tip spark plugs; there is not an actual NEED to do so.
