spark plugs to use
spark plugs to use Empty spark plugs to use
Post  fordmonsta October 8th 2013, 7:06 pm
lookin for reccomedations on what spark plug to use, its a 552 with ford racing scj heads all I can find is that they use motorcraft agsp series plugs, any help on where to start is appreciated
fordmonsta
spark plugs to use Empty Re: spark plugs to use
Post  Lem Evans October 8th 2013, 7:08 pm
Comp. ratio...rpm & application please?
Post  fordmonsta October 8th 2013, 7:15 pm
its a pump gas deal 10.25 compression prolly around 6200 shift point at most this is a motor you spec's me a cam for a few months ago lem flat tappet 643/634 lift 260/263 I think
fordmonsta
Post  Lem Evans October 8th 2013, 7:36 pm
AR-3923 should work.
Post  quick 52 October 8th 2013, 7:47 pm
fordmonsta wrote:its a pump gas deal 10.25 compression prolly around 6200 shift point at most this is a motor you spec's me a cam for a few months ago lem flat tappet 643/634 lift 260/263 I think
use to use the AR3923 but was changing when using nitrous to a AR3934 then try using the 3934 on the streets it performs very well and also runs well at the track motor or nitrous... also who's cam is that
quick 52
Post  fordmonsta October 12th 2013, 10:41 am
thanks for the help, that's is a lem evans spec'd cam I think I may have typed it wrong its a 260/263 at .050 and 640/643 lift solid flat tappet
fordmonsta
