Spark plugs
Spark plugs
Builder recommended a 14mm 3/4 reach Champion. Not sure looking at Summit what I am looking at. They have an AC Delco 19308035 Platinum Gold. This is a 10./1 solid roller pump gas street motor. Also what is the ticket on oil filters these days. I don’t think the Jomar filters are available anymore.
nedceifus- Posts : 118
Re: Spark plugs
nedceifus wrote:Builder recommended a 14mm 3/4 reach Champion. Not sure looking at Summit what I am looking at. They have an AC Delco 19308035 Platinum Gold. This is a 10./1 solid roller pump gas street motor. Also what is the ticket on oil filters these days. I don’t think the Jomar filters are available anymore.
The K&N oil filters work well.
I use NGK Iridium plugs in the race or street engines; BKR7EIX-2667.
They are usually available at most parts stores as they are used OEM on BMW cars.
nedceifus likes this post
was told to use NKG WR5-2438 V-power plugs ?
460 rebuild, pump gas, 450-500 hp ? are these the plugs to use ? also what would gap be ? thanks for advice
RANCHEROMAC- Posts : 13
Re: Spark plugs
Use a K&N filter ... what heat range plugs are you seeking ?
For an everyday street engine, I would start with an Iridium NGK - BKR7EIX -- 2667
Re: Spark plugs
IMO the BKR7 is a 7 heat range and too cold for a pump gas street build unless you're pushing 800hp and running in the 7K rpm range. On my street engines in the 600hp, 6K rpm range I run the BKR6E, one step hotter.nedceifus wrote:Builder recommended a 14mm 3/4 reach Champion. Not sure looking at Summit what I am looking at. They have an AC Delco 19308035 Platinum Gold. This is a 10./1 solid roller pump gas street motor. Also what is the ticket on oil filters these days. I don’t think the Jomar filters are available anymore.
As far as oil filters, I like the Wix XP or K&N.
Scott Foxwell- Posts : 419
