Spark plugs
Re: Spark plugs
I switched to the NGK's and with the help of the 18mm to 14mm plug adapters from Garret Machine, it opens you up to a whole range of readily available heat ranges in the more common 14mm flat washer style plugs.
kjett- Posts : 1169
Re: Spark plugs
kjett wrote:I switched to the NGK's and with the help of the 18mm to 14mm plug adapters from Garret Machine, it opens you up to a whole range of readily available heat ranges in the more common 14mm flat washer style plugs.
I use a lot of those permanent adapters in the Ford FE heads. They really work very well.
Uses washered, 3/4" reach, 5/8" hex plugs which have a whole lot of options.
Re: Spark plugs
I believe it was you and Freelander that told me to get them for my d0ves
kjett- Posts : 1169
