spark plugs
+6
jts557
342g
10 posters
spark plugs Empty spark plugs
Post  342g March 23rd 2010, 11:54 am
What spark plug is best to use with the dove head, I put the 5/8th adapter in them so I would have a better selection, I searched, found everything, but what I need to know.
342g
342g
spark plugs Empty Re: spark plugs
Post  jts557 March 23rd 2010, 12:12 pm
You need a motor to put them in first Twisted Evil Or you talking lawn mower.Stop up and see me your
retired anyway .Man you need pants in that pic
Very Happy Laughing Very Happy
jts557
Post  342g March 23rd 2010, 12:19 pm
... If you guys don't quit making fun of my legs, I am going to show the other pic., with a different body part showing. (think moon) Laughing
I hope to have a motor come time for the bash, if not, I will pull a Bruno, and set a race up with tow trucks..... cheers .
342g
342g
Post  whatbumper March 23rd 2010, 12:27 pm
I will sell anyone NGK's pretty much at cost with shipping if you know what you need. Let me know.
Post  342g March 23rd 2010, 12:35 pm
That is what I'm trying to figure which ones to buy, they have to be the ones with the gasket, but I don't know which ones, I don't know if alcohol takes a different plug than gas, need some guru help.
342g
342g
Post  whatbumper March 23rd 2010, 1:21 pm
I am at work right now but when I get home I will check which ones. I have a pretty good idea but I will let you know.
You said alcohol, gasket type.
What compression? Motor only or spray? What ignition?
Sorry for all the questions but it really helps to know for the recommendation.
Post  jts557 March 23rd 2010, 2:01 pm
Harold i have a couple different numbers here .I run 3924 autolite (just what we always stocked for years)
The middle number in the end is heat range 5 is middle and higher the hotter lower colder .I did try a couple
different numbers all about the same. but the hat sure hacks alky in anyway.
jts557
Post  342g March 23rd 2010, 9:08 pm
whatbumper wrote:I am at work right now but when I get home I will check which ones. I have a pretty good idea but I will let you know.
The compression will be 14.5-1, motor only, M.S.D 6al box anything else you need to know just ask. Very Happy
342g
342g
Post  whatbumper March 23rd 2010, 9:12 pm
Thanks, i'm on my phone now, still working, but will look it up as soon as i get to the house.
Post  whatbumper March 23rd 2010, 9:30 pm
I know I ask a lot of questions but with the adapter do you run the same reach plug or is it different than stock. If I remember right the factory reach was .460 reach. The adapter is a 18mm tapered to a 14mm gasket type I am assuming?
Post  342g March 23rd 2010, 9:45 pm
I suppose that is right,but the reach, I might better call Garrett and ask him, he don't send any info with them, just puts them in a plastic baggie, and boxes them up, and mails them, I thought some of these guys were using them, and would pass the info on to me. Laughing
342g
342g
Post  richter69 March 23rd 2010, 9:54 pm
I had good luck with AR33's when I ran the doves.
Post  342g March 23rd 2010, 10:04 pm
richter69 wrote:I had good luck with AR33's when I ran the doves.
the ar 33, was using one of the adapters Jon?
342g
342g
Post  richter69 March 23rd 2010, 10:10 pm
nope, screw right in, work damn good with alky................ Wink
Post  342g March 23rd 2010, 10:34 pm
I bought these adapters, so I could have a wider choice of plug, wonder which one would cross reference with the ar33?
342g
342g
Post  bbf-falcon March 24th 2010, 12:14 am
Harold, The AR33 is definately a better choice over any of the older(bigger) plug. It is a side gap plug which will give u alot better burn. imo.
Post  342g March 24th 2010, 12:34 am
bbf-falcon wrote:Harold, The AR33 is definately a better choice over any of the older(bigger) plug. It is a side gap plug which will give u alot better burn. imo.
Rick, you are the one that told me to buy the adapters. lol Laughing
342g
342g
Post  bbf-falcon March 24th 2010, 1:18 am
Embarassed Embarassed Hell, I did'nt know they'd be that hard to find, besides I never was a ALCOHOLIC Smile
Post  342g March 24th 2010, 9:32 am
I don't think they are that hard to find, I woud like to find the ones that crosses over, the reach is what I'm not sure about. Very Happy
342g
342g
Post  bbf-falcon March 24th 2010, 10:04 am
Contact Charlie Evans or Scotty Johnston,they should steer you in the right direction.
Post  rmcomprandy March 24th 2010, 10:53 am
342g wrote:I bought these adapters, so I could have a wider choice of plug, wonder which one would cross reference with the ar33?
AR#3933 for a domed piston or AR#3911 with an extended tip for a flat-top piston.
Post  342g March 24th 2010, 11:04 am
Now that is what I was looking for, .... THANKS RANDY. Laughing Laughing
342g
342g
Post  jts557 March 25th 2010, 1:27 pm
Harold im pretty sure i have all that info here.Also we can just take them out and look at them.
BTW was that your dully at the tanning place down the street . Twisted Evil At least the white legs go good
with the car Mad
jts557
Post  bb429power March 25th 2010, 7:38 pm
All you need is Champion spark plugs. You don't need to get fancy, and don't buy the E3 Diamond-fire plugs. You have to run the high octane pump gas all the time for them to work. They're apparently crap, my brothers friend put them in is truck, had to buy different ones. One type that I liked was Split Fire, they worked just fine and will probably put them in my 466.
bb429power
bb429power
Post  bbf-falcon March 25th 2010, 9:54 pm
bb429power wrote:All you need is Champion spark plugs. You don't need to get fancy, and don't buy the E3 Diamond-fire plugs. You have to run the high octane pump gas all the time for them to work. They're apparently crap, my brothers friend put them in is truck, had to buy different ones. One type that I liked was Split Fire, they worked just fine and will probably put them in my 466.
I would'nt run a Champion plug in a weed eater No Smile
