spark plugs
spark plugs
how does the heat range compare between an autolite ar 3935 and a 3922 also is a ar 3934 hotter or colder than an ar 3935?
Larry Williams- Posts : 884
Re: spark plugs
do they make an ar 3922?
Re: spark plugs
Larry Williams wrote:do they make an ar 3922?
I'm not sure.......but there is a AR3932
Re: spark plugs
how would that compair to the 3922 as far as heat? the 3922 is not a side gap plug
its what the afr recommends as a starting point
heat range chart for autolites
Autolite heat range chart, and cross refrence chart.
http://www.autolitesparkplugs.com/glossaryImage.asp?imgID=700
http://www.autolitesparkplugs.com/glossaryImage.asp?imgID=701
kim- Posts : 700
