Best BBF cylinder head for big cubic inch motor
Mahoney3105
what is the best BBF cylinder head out there for N/A combo at 665 ci
Mahoney3105- Posts : 28
Re: Best BBF cylinder head for big cubic inch motor
class rules ??? thor or the profiler .......... or maybe a one off billet
there is a post listing the cylinder heads in order. Maybe Bruno can steer you to it
Larry Williams- Posts : 884
Is Tony B. going to be your engine builder? If so, go with whatever he says. Is this going to be a single four deal, or a 2 X 4 tunnel ram? Is it going to a nitrous fed engine? How much? Is it going to be a 5.0" bore spacing deal? All these questions come into play, so tell us a little more please.
The case can be made for the canted valve Pro-Filer 205 heads, the Thor heads, (either Gen 1 or Gen 2), the 1500 IDT heads, the B441 heads that Randy mentioned, and finally the GT Heads 14* 5" bore spacing head from Greg Burkhart could also be considered.
Right now we're getting 576 cfm out of the 1500 IDT heads, and I understand Tony is getting 581 cfm. Another gentleman in Lousiana is getting like 572 cfm. Kinda' ironic that we are all so close.
Charlie
Charlie
c.evans- BBF VENDOR SPONSOR
I'm building a 665 CID also, (if I ever get back around to it) and I'll be using the Pro-Filer 205 canted valve heads. If this link works you can see a picture. https://www.429-460.com/t12788-pic-s-of-seminar-and-things-that-went-down?highlight=winter+tech+seminar
Motor will be a 665 ci sheet metal single stretched CFM carb 4.900 bore space Max effort N/A deal
Profilers canted valve or thors if you sticking with wedge heads.
The IDT 1500 stuff is still pretty new, I'd want to see a few sets running and see how they perform.
The Hemi heads are never a bad choice.
http://www.460ford.com/forum/showthread.php?t=97305
cylinder head pecking order
Another Ford Hemi head that certainly is worth consideration is this one from Dave Bamber. http://bamberengineering.com/portfolios/billet-aluminum-cylinder-heads/billet-hemi-head/
» Will Jesel Rockers From A Yates Head Work On A C-460 Cylinder head?
» whats the best cubic inch for a c head combo
» A460 cylinder head question
» Cylinder Head ID Help
» which cylinder head do I have?
