Block plugs
Block plugs Empty Block plugs
Post  OldRedFord October 10th 2009, 2:29 am
What are the two plugs on the outside of the block for? One on each side towards the rear. Also what are the two plugs in the lifter valley towards the back? What purpose do they serve?
OldRedFord
OldRedFord
Block plugs Empty Re: Block plugs
Post  chuck stevens October 10th 2009, 1:43 pm
The plugs on the outside of the block are drains for coolant, they go into the jacket. The plugs in the valley "tower" are to plug the grillings for oil to cross over from the right to left bank of lifters.
chuck stevens
http://E-MAIL= stevensracingent@aol.com
Post  OldRedFord October 16th 2009, 3:01 am
I ask because the one coolent plug in the outside of the block, I went to remove it and I stripped it out. It turned about a 1/8 of a turn tho. How hard would it be to drill it out? Or will it be ok since it hardly moved?
I guess I had the wrong allen wrench. It fit nice and snug tho.
OldRedFord
OldRedFord
Post  bosshoss October 16th 2009, 3:05 am
I have carefully drilled and retapped a few of those over the years. Not a problem if you take your time.
I usually replace them with a petcock so I can drain the block.
dkp
bosshoss
bosshoss
Post  OldRedFord January 25th 2010, 11:45 am
What size are the two plugs in the water jacket?
OldRedFord
OldRedFord
Post  bosshoss January 25th 2010, 2:33 pm
1/4" npt
dkp
bosshoss
bosshoss
