A460 block oil gallery plugs
When installing the oil gallery plugs, is there a certain depth that any of them need to be set at? This is a solid roller engine.
tconnection- Posts : 866
Re: A460 block oil gallery plugs
Until they are tight.
Make them tight.....use sealer on the rear 3/8" npt plugs.
Biggest deal... is be sure to put the 1/4" npt plugs in the upper passenger side to restrict the oil to the valvetrain.
One or both will have to be drilled to let oil to the lifters and other valvetrain.
» oil gallery plugs c&c RD 429-460 aluminum block
» distributer block hole is too small on an A460 block
» Block Plugs
» A460 spark plugs
» Spark plugs for a460 heads
» Block Plugs
» A460 spark plugs
