Windage tray!!
+11
Bret Powell
466cj
bigblok2000ranger
madman
15 posters
Page 3 of 3
Page 3 of 3 • 1, 2, 3
Re: Windage tray!!
I had one do that,only worse in a engine a few yrs back w/Milidon front sump. After further inspection,I found block cracked all the way from#2 main up to cam journal. Cap walk from BADD tune. Check it out good. Good luck;)
Re: Windage tray!!
Thanks guys, I'm pulling it this winter and going through it. We had pulled the pan and tray out but found nothing that could be hitting it. That piece was actually on the outside top of the tray behind the tray frame itself right where the screen is welded to the tray frame.
70FB- BBF CONTRIBUTOR
Re: Windage tray!!
I hope not......bbf-falcon wrote:I had one do that,only worse in a engine a few yrs back w/Milidon front sump. After further inspection,I found block cracked all the way from#2 main up to cam journal. Cap walk from BADD tune. Check it out good. Good luck;)
» Need windage tray
» Windage Tray
» Is the Mildon Windage tray Preferred over the Canton screen type one?
» Windage tray
» Does a high volume oil pump necessitate a high volume oilpan?
» Windage Tray
» Windage tray
Page 3 of 3
