429SCJ
466cj
4speed
IDIeselman
Super Snake Steve
429SCJ Empty 429SCJ
Post  Super Snake Steve January 4th 2013, 1:44 am
I have a 429SCJ I built in 1985 has 10k miles runs great but I was reading a thread some one asked about solid lifter cam for street and some one chimed in about no zinc in oil these day so my question is why do you need zinc for solid lifters and what is the best oil for my motor can you buy zinc and add it to say synthetic oil if so were can I get it and what weight oil should I use like I said I have solid crane cam with crane rollers thanks for any help about this problem
Super Snake Steve
429SCJ Empty Re: 429SCJ
Post  69F100 January 4th 2013, 1:50 am
You can get the zinc additive at Advance Auto Parts it will tell you what oils you can add it to I have a solid lift flat tappet also I run rotalla 15w40
Post  Super Snake Steve January 4th 2013, 1:53 am
Thanks do you know why you have to use it on solid lifters
Super Snake Steve
Post  IDIeselman January 4th 2013, 9:18 am
Clickey>>> http://lesfrickshun.com/ZINC__ZDDP_.html
Simply put, it is a lubricant that was once standard in most common oils but has now been reduced/removed.
IDIeselman
IDIeselman
Post  4speed January 4th 2013, 11:11 am
I think the zink thing pertains to flat tappet. Not so much with roller
4speed
4speed
Post  IDIeselman January 4th 2013, 11:56 am
"If you are old enough to remember the days of leaded gasoline, no lead worked fine at the expense of valve seats and valve guides. The same is true today, current SM oils will work in your performance engines, but at the cost of accelerated camshaft wear, timing chain to gear, push rod to rocker arm, piston to pin and pin to connecting rod. The list goes on. Although, the ZINC (ZDDP) additive package was aimed at the flat tappet market, you can see the need in roller motors, when you look at all the other parts affected." Personally I would not run without it in any performance engine I own.
IDIeselman
IDIeselman
Post  466cj January 4th 2013, 9:34 pm
I'd look for an oil formulated for your engine. Joe Gibbs, Lucas, Brad Penn are just a few that come to mind that make engine oils for older engines like yours.
466cj
Post  BOSS 429 January 5th 2013, 12:44 pm
Super Snake Steve wrote:I have a 429SCJ I built in 1985 has 10k miles runs great but I was reading a thread some one asked about solid lifter cam for street and some one chimed in about no zinc in oil these day so my question is why do you need zinc for solid lifters and what is the best oil for my motor can you buy zinc and add it to say synthetic oil if so were can I get it and what weight oil should I use like I said I have solid crane cam with crane rollers thanks for any help about this problem
Since it has 10k on it all ready its already broke in.No real need to add zinc now, just run a good oil such as brad penn
Post  Super Snake Steve January 5th 2013, 7:04 pm
I found two hy-per lube for flat tapper cams but does not have zinc in it or phosphorous in it and Lucas engine oil additive but says to drain after 1000 miles so will the first one work even if it don't have zinc in it but is made for flat tappets. And yes I remember leaded gas and still by lead for my gas I rebuilt this motor in 85 and it has only 10k miles and the valve job is a back in the 80s 3 angel valves job with old seats for leaded gas anyway I want the best for my baby and need to get the right additive for her i like for my girl to be well lubed even if some one know a web site to get the right stuff thanks
Super Snake Steve
Post  LivermoreDave January 6th 2013, 9:26 am
First item of attention is valve spring pressure. Is your valve spring pressure appropriate in regard to your application? To answer your question as to why, the wear protection of today's oil is not what it was, before roller lifters and such entered public transportation. An oil pan that contains a quality oil, petroleum or synthetic and an additive that contains Zinc will do fine as long as your spring pressures are in line and you maintain a good tune-up. I have good performance from The COMP additive.
Dave.
LivermoreDave
Post  Super Snake Steve January 6th 2013, 12:47 pm
Thanks guys I have learned a lot on this I found some oils that have zinc and have been reading else where amsoil makes one with zinc in it like 1300 ppm and brad penn oil and comp additives I'm thinking of going with the amsoil one anyone use It I think it's z rod or q rod something like that
Super Snake Steve
Post  maverick January 6th 2013, 1:01 pm
Mobil 1 15W50 has high zinc content. A little googling will get you more oil info than you want. Cool
Post  71maverick January 6th 2013, 10:32 pm
I work at a caterpiller dealer and go to lots of training classes on machines..hyd...engines..etc.. CAT uses roller cams and lifters in most all their engines. They dont make their oil but do have it mixed so to speak to meet their requirments.. They also say zinc plays a vital role in engine life.. If you look on the back of a gal of their oil it says CI4/CI4plus. I have been told this referrs to how many parts per million(ppm) of zinc is in the oil. At one time i had a sponser that provided all my engine oil(penzoil). We ran it for about 3yrs and changed every other weekend.. Since i attended the cat class on engine life i switched to the cat oil(15-40). I can tell you my bearing look much better after 150 passes than ever before.. And i have ran my cam which is over .800 lift for 4 yrs and still looks great. Just my 2ยข. If you got a cat dealer near buy its about $80 for 5 gal or can be bought by the gal
71maverick
71maverick
