Before I button it up which rod bolts
Before I button it up which rod bolts Empty Before I button it up which rod bolts
Post  738drvr January 10th 2013, 11:57 pm
Came with 8740's. Assembly has been balanced.
Scat 4.500 crank
Eagle 6.800 H beam
552 should turn 65-6700 rpm. 700+ N/A plus a 100-150 shot.
Pistons weigh 566 g.
8740's or 2000's?
Before I button it up which rod bolts Empty Re: Before I button it up which rod bolts
Post  c.evans January 11th 2013, 12:50 am
Don't change rod bolts now, unless you want to resize the big ends. Use the bolts that came in those rods, (the 8740s) and they will be fine at the power level and that rpm.
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  738drvr January 11th 2013, 8:46 am
Thanks Charlie. I read on this site that Eagle states you can run the 2000's without re-sizing. The L-19's require re-sizing. Just want to make sure I'm safe.
Post  466cj January 11th 2013, 1:25 pm
If you decide to go with the 2000 bolts you will need to have the rod big end checked. Any time the clamping force is changed it is possible that the bearing housing will distort. This is why the rod big ends are always honed with the bolts installed with the correct lube and are torqued or stretched to spec before honing.
466cj
