thrust bearing clearance end play and rods
thrust bearing clearance end play and rods  Empty thrust bearing clearance end play and rods
Post  74f100 January 13th 2013, 9:32 am
just wondering what every body likes for thrust bearing end play stock crank / crank was fat so just poilshed
and line bore and also clearance between rods motor has been balanced and rods resized speed pro flat tops going to turn about
4500to 5000 thanks
74f100
74f100
thrust bearing clearance end play and rods  Empty Re: thrust bearing clearance end play and rods
Post  Lem Evans January 13th 2013, 12:42 pm
.005" crankshaft end play would be about right for your application. Ford's spec is .004"-.008" so you could be a little wider if you wish.
Post  74f100 January 13th 2013, 1:29 pm
thats cool it is 006"for crank thrust thanks
74f100
74f100
Post  cooter January 13th 2013, 10:20 pm
rod clearance should be about 15 thousands
cooter
