cam thrust plate
cam thrust plate
Any recommendations for a cam thrust plate? Stock block, roller cam, billet steel timing Cloyes timing set.
I was looking at this: Ford Racing M-6269-A460
Suggestions?
Suggestions?
the1969fordguyinky- Posts : 237
Re: cam thrust plate
The bronze cam retainers are a direct bolt on [no gear machining] and are less money than the FRPP A460 unit .
Bronze plate ordered from B.F. Evans Race Parts!
Thanks for the info Lem.
the1969fordguyinky wrote:Bronze plate ordered from B.F. Evans Race Parts!
Thank YOU
Like Lem and Terry said...
No score for this post November 17 2005, 8:28 AM
If using a roller cam, either use a bearing deal or a bronze plate. Don't risk it, because all the metal in the motor and the potential cam walk is not worth the risk.
PFC Engines 573-793-2177
DTS Dyno and SuperFlow SF600 equipped!
"Pullin For Christ"
"Pullin For Christ"
» Cam thrust plate and water pump baking plate questions
» Camshaft end play
» Cam thrust plate options?
» Camshaft thrust plate : what do I need and where can I buy
» camshaft thrust plate bolt torq spec
» Camshaft end play
