Camshaft thrust plate : what do I need and where can I buy
Hi all.
Done a number of searches but have to many mixed results.
I did find one topic and everyone voted Brass fits all. And a US phone number but I am in Australia and normally buy from Summit simply because of freight charges, happy to buy from ebay or another a sponser seller but paying $50-70US UPS is not what i am after.
So.
Early 460 - 385'
Ford 460 Compcams Hyd flat tap cam (cast?)
New double row gears. I belive cam gear is iron (compcams)
Can I use normal cast plate?
Can I use steel plate ?
Looks like I can use Brass for anything that moves.
Can I buy a SMF 351C 400M plate? (Told by proflow reseller same?)
What is the spec / wear tollorance ? My current item may be fine.
And what is the end play tolerances spec once installed? I have s few books but dont recall it setting this. The old cam float movement appeared to be very generous.
Thanks in advanced
R
So.
Early 460 - 385'
Thanks in advanced
R
bigblockfordfxstb- Posts : 125
Re: Camshaft thrust plate : what do I need and where can I buy
Cast gear, use a cast (stock) plate. DON'T use a steel plate with a cast gear. You can use brass, but why bother? No benefit.
pmrphil- Posts : 170
A stock plate in good condition will work. Check for any wear grooves . Check camshaft endfloat will tell also
For a bronze plate I believe I've seen Lem Evans has them
Cam endfloat in my Ford book is listed as desirable .001"-.006" , max .009". Last few i've done have come in @ .004"
Gregaust- Posts : 625
Hmmm ,can't see the pics , just wondering if you have a lot of endfloat , some gears have a brass/bronze washer between cam gear and retainer plate , a chance that is missing ??
The back of the gear has a step built into it and goes into the recess, taking up most of the "loose" endplay
You need to check endplay with the cam gear installed and torqued to spec.
To keep it simple - Cast cam core = cast plate and cast gear........ Steel cam core = bronze plate and steel gear... This is what I've learned over the years.
jbozzelle- Posts : 3705
» camshaft thrust plate bolt torq spec
» PART NEEDED ASAP CAM THRUST PLATE ROLLER
» cam thrust plate
» Camshaft end play
» Cam thrust plate options?
» cam thrust plate
» Camshaft end play
