Camshaft end play
2 wicked
Axshun
Camshaft end play Empty Camshaft end play
Post  Axshun July 16th 2020, 4:36 pm
Hey guys,
I'm in the process of installing my hydraulic roller cam into my 521 with a bronze thrust plate from Kaase. When I torque the thrust plate to the recommended torque of 9-12 ft. lbs., it binds the cam so it will not turn.
Is there a recommended end play for the camshaft? I can't seem to find a spec in the book and a search here didn't turn up anything. It turns fine with the lifters in until I tighten the plate.
Could the machine shop have pressed in the back plug to far, or what is the best way to get the clearance I need?
Thanks in advance!
Axshun
Camshaft end play Empty Re: Camshaft end play
Post  2 wicked July 16th 2020, 5:34 pm
Axshun, their are only two reasons that would cause no end play. Either than cam bore plug is in too far or the cam is machined too long. Cam retainer/thrust plate will only effect endplay when cam gear is installed. Hope this helps. PS- paint the rear of cam with a marker and install the cam and retainer . Then turn cam as u snug the retainer bolts. If the cam is hitting cam bore plug it will leave a witness mark. Good luck
2 wicked
Post  Axshun July 16th 2020, 8:49 pm
Thanks for the reply....
After doing some research, I've seen people say not to put the plug in past the taper on the block. Mine definitely is past the taper, so I guess I'll be pushing the plug back out and re-installing it. I've also read where some people are installing the cam plug as an "outie". Mine is installed as an "innie". What's correct for the 460?
Axshun
Post  2 wicked July 16th 2020, 8:57 pm
I have seen them installed both directions. If u knock it out replace with a new one. As they are a crush fit. I always apply a little rtv sealer around outside edge after installed. Glad u found the problem.
2 wicked
Post  Gregaust July 17th 2020, 5:11 am
The "OUTIE" is an FE block thing. Never seen that on a 460
Gregaust
Post  Lem Evans July 17th 2020, 7:41 pm
Cam plug in too far is my 1st guess. .003" end play is enough.
Post  stanger68 July 19th 2020, 11:04 am
FE is the only engine I know of that the rear plug installs backwards.
Post  Axshun July 21st 2020, 7:29 pm
So I installed a new plug and all is well! The machine shop had installed the old one in too far.
Thanks for the replies!
Axshun
Camshaft end play Empty Thrust plate
Post  Gary Blair July 31st 2020, 6:23 pm
Roller Thrust is better.
Gary Blair
Gary Blair
