Cam thrust plate options?
+15
Gregaust
68galaxie
nitro717
bigjohn2007
'65 T-BOLT
D. Sea
Race Ready Fabrications
19 posters
Page 1 of 2
Page 1 of 2 • 1, 2
Are there any good alternatives to the stock deal? Seems I've chewed up a stock one when the cam bolt worked loose. Found a couple of roller bearing deals. Are they worth the money ? Thanks Brian
Race Ready Fabrications- Posts : 619
Re: Cam thrust plate options?
Lem Evans wrote:The bronze plate i.m.o. No machining required.....just bolts on.
X2
richter69 wrote:Lem Evans wrote:The bronze plate i.m.o. No machining required.....just bolts on.
X2
X3
D. Sea- Posts : 2768
'65 T-BOLT- Posts : 1464
if its a roller cam, use a thrust roller style plate,friction is reduced
BOSS 429- Posts : 2371
Ordered one todayLem Evans wrote:
bigjohn2007- BBF CONTRIBUTOR
That's not were any real friction is in the engine. Not my opinion....fact.BOSS 429 wrote:if its a roller cam, use a thrust roller style plate,friction is reduced
just buy a Danny Bee and be done with it......
the Coug- Posts : 3055
No more wear than I have seen on my deal over the years with the bronze thrust plate, I think I would swap having the chance of all those tiny rollers getting down into the oil pan and maybe causing problems for the plate.
Just my 20 years worth of bronze plate experience.
X6 Just run over to Lem's and pick one up, or call Shawn in the parts department (270)278-2376, and he can ship one to you. He has them in stock. I had one in Krisse's 533 unit and it did fine,,,, that was like 3 or 4 years ago and that engine is still in service.
Uncle Charlie
Uncle Charlie
c.evans- BBF VENDOR SPONSOR
IDT-572 wrote:No more wear than I have seen on my deal over the years with the bronze thrust plate, I think I would swap having the chance of all those tiny rollers getting down into the oil pan and maybe causing problems for the plate.
I have tore apart 2 different engines w/those roller bearings in the pan. So it's Bronze for me also.
D9TE 528 with bronze plate:Race Ready Fabrications wrote:Are there any good alternatives to the stock deal? Seems I've chewed up a stock one when the cam bolt worked loose. Found a couple of roller bearing deals. Are they worth the money ? Thanks Brian
D0VE 533 with CampCams bronze plate for Torrington bearing cam gear:
The standard (non-Torrington applicable) bronze plate ought to suffice.
Paul
I have been running the factory thrust plate.
I have a Crane roller cam. I was under the impression that the oil pump loading "pulled" the cam rearward?
Would this mean any camshaft with an aftermarket steel timing set should use the bronze thrust plate?
Cheers
Cheers
68galaxie- Posts : 351
So with a Solid flat tappet is a stock plate ok? or is the bronze plate better ? I have used the Ford Racing roller plate with a roller cam .
I have a spare roller plate i was going to use in another motor with the Solid cam but thinking twice now that the bronze or stock plate would be better .
Any harm or benefit using the Ford Racing roller thrust plate with a solid flat tappet cam ??? Seems the Bronze plate is good all round
Gregaust- Posts : 625
Generally, the distributor gear is pulled downward and the camshaft is moved rearward. However, camshafts can sometimes move forward in some combinations due to other aspects of the design or setup of the engine, such as when there is no internal oil pump, etc.68galaxie wrote:I have been running the factory thrust plate.
Cheers
Paul
68galaxie wrote:Would this mean any camshaft with an aftermarket steel timing set should use the bronze thrust plate?
Cheers
In very general terms, the bronze plate is pretty much the no-brainer, one-size-fits-all option. But it's not a "must" in all cases.Gregaust wrote:So with a Solid flat tappet is a stock plate ok? or is the bronze plate better?
I have a spare roller pla.
Paul
The cam is pushed forward if you use offset lifters, this is a fact I learned the hard way. My c-headed 605 I used centered lifters for 2 seasons with a stock cam thrust plate with no wear at all to speak of. I had some trouble breaking snap rings on the intake rocker because of the side load. I thought I would try a set of offset lifters to try to straighten the push rod a bit to reduce side load. Ran the engine on the test stand for 5 min and pulled the plug and filter and the magnet on the plug had a mushroom of iron on it. After tear down I tried another stock thrust plate blaming myself for assembly error. Tried it again same thing happened, with only changing the lifters I studied it for awhile and noticed that the offset lifters are turned slightly in the bore under pressure, and tries to thread the cam forward. The reason I think I never heard of this before is because everyone I talked to about the issue never used a stock plate on a high end engine build , it was either a bronze plate or a roller style.
strokedmyford- Posts : 126
Yep, the off set cups in the lifter trys to rotate the lifter in the bore......loads the tie bar also.
anyone have the part number to the comp bronze plate. cant find it at comp or summit.
cobra501- Posts : 95
Lem sells them- http://www.460ford.com/forum/showthread.php?t=151456
,Lem Evans wrote:That's not were any real friction is in the engine. Not my opinion....fact.BOSS 429 wrote:if its a roller cam, use a thrust roller style plate,friction is reduced
Ill stick to the roller bearing ones for roller cams, never a bearing in the pan,or a cam that failed of any kind ,but ive seen plenty of worn thrust plates
Page 1 of 2 • 1, 2
» Cam thrust plate and water pump baking plate questions
» cam thrust plate
» Camshaft end play
» Camshaft thrust plate : what do I need and where can I buy
» PART NEEDED ASAP CAM THRUST PLATE ROLLER
» cam thrust plate
» Camshaft end play
Page 1 of 2
