78 F150 where to put the bottle
+8
4thHorseman
fordmanmatt
2fox
quick 52
BigBoy460
12 posters
78 F150 where to put the bottle Empty 78 F150 where to put the bottle
Post  BigBoy460 January 17th 2013, 8:01 pm
I was thinking behind the seat what do you guys think, if this is ok while I am redoing the interior should I run any wires or tubing under the carpet before I install it???
BigBoy460
78 F150 where to put the bottle Empty Re: 78 F150 where to put the bottle
Post  quick 52 January 17th 2013, 11:47 pm
you need to set the valve to the front the truck if there room for it why not myself im in the bed with mind
quick 52
Post  2fox January 19th 2013, 3:36 pm
I haapen to own a 83 F100 with 408w behind the seat would be okay if you seat will accomadate it? If not what about the side corners behind the seat? Or under the frame rail. I asume you wanting to hide it? Are cut the foam out behind the seat that where I mounted my high dollar amp at. You don't have crewcab? Or rear seats I mean
2fox
Post  Frank Merkl January 19th 2013, 5:12 pm
it would be a lot safer with the bottle in the bed , If you put it in the cab make sure you change the fitting for the blow off disc and a blow off tube adapter installed and a blow off tube to the exterior
Post  supervel45 September 5th 2013, 9:30 am
I put mine behind the seat in my 78 F150 and it worked fine. You don't have to get out to turn it on, and nobody see's it, are the benifits. Bottle not facing foward is the supposed drawback, but did not seem to cause any problems.
Post  fordmanmatt January 20th 2014, 9:55 pm
Good Info
fordmanmatt
fordmanmatt
Post  4thHorseman January 30th 2014, 11:06 am
Bottle don't have to be pointing forward, as long as pickup tube it orientated properly.
78 F150 where to put the bottle Bottle10
4thHorseman
4thHorseman
Post  whatbumper January 30th 2014, 11:10 am
Or stand it up behind the seat.
Post  res0rli9 January 30th 2014, 2:18 pm
I'd put it in the bed...I wouldn't want a bomb under my ass affraid
Post  77f150 January 30th 2014, 8:47 pm
My vote is the bed, besides I don't have room anywhere else  Very Happy
78 F150 where to put the bottle P1020703-1
77f150
77f150
Post  DILLIGASDAVE January 31st 2014, 4:15 am
If this truck will see any street use I wouldn't put the bottle in the bed.
4thHorseman wrote:Bottle don't have to be pointing forward, as long as pickup tube it orientated properly.
I mounted a bottle this way too behind the pass seat in a Ranchero I had. Made it easy to hide on the street just by throwing a jacket over it.
whatbumper wrote:Or stand it up behind the seat.
X2. If there's enough room behind a truck's pass seat to stand the bottle up, this IMO is the best way to mount a bottle in a truck.
Post  Ford78250 March 2nd 2014, 4:49 am
Placed it behind the seat on my 78 F250... it's a street legal pulling truck with a regular cab and flatbed so I wasn't crazy about the idea of a bed mount.
Ford78250
