Guide plate machining
How much should be milled off of the stud pedestals for guide plate installation on C8VE heads. I assume the same amount as the thickness of the guide?
fordguy69- Posts : 98
Re: Guide plate machining
fordguy69 wrote:How much should be milled off of the stud pedestals for guide plate installation on C8VE heads. I assume the same amount as the thickness of the guide?
yes the same amount as the thickness of the plates
69F100 wrote:fordguy69 wrote:How much should be milled off of the stud pedestals for guide plate installation on C8VE heads. I assume the same amount as the thickness of the guide?
Actually, a bit more.
At LEAST the thickness of the guideplates but, Ford recomends .230" to get the pushrods near correct alignment if you use a flat Ford guideplate.
» Guide plate ?
» AFR guide plate installation
» Pushrod to guide plate clearance
» eddelbrock push rod guide plate part # or equivalent
» P51 heads with Kaase guide plate pushrod diameter
