C-6/with a brake
bigblok2000ranger
butterbean
C-6/with a brake Empty C-6/with a brake
Post  butterbean January 26th 2013, 6:52 pm
can you build a C-6 w/a brake relatively cheap and have it live in a 3300# car with 750 hp?????? thanks Butterbean
butterbean
butterbean
C-6/with a brake Empty Re: C-6/with a brake
Post  bigblok2000ranger January 26th 2013, 8:01 pm
Yes.
bigblok2000ranger
bigblok2000ranger
Post  butterbean January 26th 2013, 8:53 pm
how much did it cost you to build yourS??????????
butterbean
butterbean
Post  bigblok2000ranger January 26th 2013, 9:27 pm
About $1200, but that is with billet r code servo, billet e ratio apply lever, all red alto clutches, Trans brake valve body, 3" wide rigid kevlar band, four clutch forward drum and a stepped pressure plate for 5 clutches and steels.
bigblok2000ranger
bigblok2000ranger
Post  butterbean January 26th 2013, 10:33 pm
do you have a good tranny guy? when I get to that point I may pay shipping to get it done by a good builder
butterbean
butterbean
Post  bigblok2000ranger January 26th 2013, 10:59 pm
Where are you located their may be some good builders near you?
bigblok2000ranger
bigblok2000ranger
Post  butterbean January 27th 2013, 11:42 am
naples, Fl no good builders that I know of, I don't even know of any in so. Fl anywhere, all the racers down here think there is only one trans and that is a PG
butterbean
butterbean
Post  bigblok2000ranger January 27th 2013, 4:31 pm
Michael Whitefield would probably be closest to you that I know of.
bigblok2000ranger
bigblok2000ranger
Post  BOSS 429 January 28th 2013, 9:32 am
call bill borsom to do your trans,
815,419 -1457 He's real busy with trans builds at this time, leave a mess, He will call you back
Post  yellowhorse7 January 28th 2013, 9:57 am
BOSS 429 wrote:call bill borsom to do your trans,
X2. Had a Dynamic X6 C4 that failed after 10 passes. Bill freshened it, changed a few things and have had no issues since. Local Chicago guy who does it out of his house but it will be done right!
yellowhorse7
yellowhorse7
Post  schmitty January 28th 2013, 10:49 pm
You could try Frank Merkl too. He is Canada, but it would be well worth the ride up there to get it done. He is the only guy I know that has had a C6 go in the 7's in the 1/4. He can be contacted here on the board. Cool
C-6/with a brake Empty c6 with brake
Post  v-twin June 2nd 2013, 8:50 pm
I have tci c6 with a brake behind a 521 kaase head ,2000 mustang 30 passes no problem ,also street driven to the track at Bristol,tn 9.72 137mph no power adder
v-twin
v-twin
