solid flat tappet cam
looking for a used aggressive solid flat tappett cam and lifter set maybe in the mid to upper 600 range and duration 260-270 range at .50
hustler 1- Posts : 1
Re: solid flat tappet cam
Got a New one for ya, but you'll have to wait until I get back home in March if you want it.
$100 + shipping.
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=1019&sb=0
$100 + shipping.
I have the same cam and the lifters that go with it for $140. plus shipping.
I've got (2) that are just layin around.
CAM 2010: ran (1) season, about 350 passes, mostly 1/8 mi.
INT EXH
lobe 802F 313A
dur @ .050 266 276
gross lift 705 638
113 deg lobe sep.
CAM 2011: ran (1) season, about 350 passes, mostly 1/8 mi.
INT EXH
lobe 307F 320B
dur @ .050 271 283
gross lift 711 667
112 deg lobe sep
Both are BULLET CAMS.
$150 for a cam / solid lifter set + the ride.
INT EXH
lobe 802F 313A
dur @ .050 266 276
gross lift 705 638
113 deg lobe sep.
INT EXH
lobe 307F 320B
dur @ .050 271 283
gross lift 711 667
112 deg lobe sep
JACKAZZFLATZ- Posts : 249
CAM
I have a brand new, Cam & lifters....
INTAKE DUR: @ (.050) 268.7 With .658 lift & 106.0 centerline.
109.7 LbSep.
EXH DUR: @ (.050) 275.1 With .686 lift & 113.4 centerline.
With notched Solid lifters.
I had this installed but never started, PM if more info is needed.
$200.00 PLUS THE RIDE........
Thanks.
Ed.
109.7 LbSep.
Thanks.
Ed.
ROAD RAGE- Posts : 229
» EDM holes in solid flat tappet
» Solid flat tappet limitations
» Custom solid flat tappet for nitrous
» Comp solid flat tappet cam, lifters etc
» A460 heads with solid flat tappet
