Another head question.
Another head question. Empty Another head question.
Post  fordguy69 January 29th 2013, 10:04 pm
Which small chamber (75cc or thereabouts) aluminum heads bolt on without special piston configurations or flycuts? And have stock intake and exhaust port locations. For instance, using them on a 72 stock piston short block.
I have bent the valves in my C8VE's and want to go aluminum.
fordguy69
Another head question. Empty Re: Another head question.
Post  rmcomprandy January 29th 2013, 10:58 pm
fordguy69 wrote:Which small chamber (75cc or thereabouts) aluminum heads bolt on without special piston configurations or flycuts? And have stock intake and exhaust port locations. For instance, using them on a 72 stock piston short block.
That depends mostly upon the pistons used and exactly which valve sizes are used in the small combustion chamber heads.
Post  dfree383 January 30th 2013, 12:16 am
TFS Streets
Edelbrocks RPMs / Victors
Blue Thunders
Old Ford A429's
Like randy in eluding to the valve pockes on your pistons may need enlarged depending on what valve sizes you use and the pistons you have. It needs to be checked.
