A-460 HEAD QUESTION
A-460 HEAD QUESTION Empty A-460 HEAD QUESTION
Post  mustang557 January 22nd 2013, 7:16 am
I HAVE A SET OF FORD MOTORSPORT A-460 HEADS, WOULD LIKE TO KNOW IF THE VALVE ANGLE ON ALL
A-460 HEADS ARE THE SAME SO THAT YOU COULD USE ROCKER GIRDLES FROM NEW STYLE 18 BOLT A-460
HEADS? ALSO ARE THE EXHAUST PORTS ON MY (CHEVY DESIGN) HEADS THE SAME HEIGHT AS ALL LIKE
A-460 HEADS FOR HEADER ORDERING? Shocked
mustang557
A-460 HEAD QUESTION Empty Re: A-460 HEAD QUESTION
Post  dfree383 January 22nd 2013, 7:54 am
The girdels work.
As far as the headers, BBC stuff will work but you may have to slightly slot some bolt holes. also of you have BT BBC exhaust ports heads and headers fitted for them you could experiance fitment issues, because the A460 ports are quite a bit higher than the BT heads.
A-460 HEAD QUESTION Empty EXHAUST PORT LOCATION
Post  mustang557 January 22nd 2013, 6:47 pm
ARE THE RAISED PORT DESIGN ON THE EXHAUST THE SAME ON ALL A-460 HEADS OR ARE SOME HIGHER THAN
OTHERS? Shocked
mustang557
Post  c.evans January 22nd 2013, 8:51 pm
Same. If you have a one piece flange, then be prepared to saw it into three times between the four primary pipes. The old style Motorsports A-460 heads have the ports on 4.900" centers, whereas the new style TFS heads have the ports "clustered" towards the Chevy bore spacing of 4.840".
Hope this helps,
Uncle Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
