head question
head question
I know procomps don't make for lots of power on na motor but would a properly setup set make power under boost. Beings that they have large combustion chambers to lower compression? Plus aluminum would cut down on detonation vs a d3 just a thought thx
waypastcrazy- Posts : 165
Re: head question
This may be a place for these heads actually. The exhaust port design and flow capabilities would lend it to a turbo situation if a guy wasn't looking for the "best". Vandy made well over 1000 HP with a blower and iron heads back in the day, so making some good power with the P/C's by adding boost would be very possible.
schmitty- Posts : 4538
Re: head question
If you haven't already bought them, then I don't understand why you would want to waste your money and buy a set. All the other aftermarket BBFord heads are better period...
It sounds like you are trying to find a place to use them, when you mentioned using them under boost. IMO if you are going to supercharge or turbocharge a BB Ford engine, then let's think about using an 18 bolt head, it makes for a better head gasket. Furthermore, if you are going to supercharge or turbocharge the engine, then let's give it the best exhaust port we can, and than would mean several other heads such as the B.T. raised port Chevy exhaust, or better yet the A-460 or C-460 heads. My point being that if you are going to use a head under boost, then again there are a bunch more out there that I would rather have over the Pro Comp heads.
Hope this helps,
Charlie
Hope this helps,
Charlie
c.evans- BBF VENDOR SPONSOR
Re: head question
Good response. No I don't want to find a use for them.just a thought while I was looking at the options of open chamber heads for a street turbo. Sure wish the tfs street was in a 95 cc chamber
» Another head question.
» A 460 Head Question
» Head question
» 429 Head Question.
» P51 Head Question
» Head question
» P51 Head Question
