c6 valve bodies
c6 valve bodies
must be early C6's '68-'71 , casting numbers on the vb must be - on the upper half C8AP in the casting ,this is the shift detent in the vb casting and the lower half will have C7AP in the casting # . Will pay $100 ea delivered to me , these can be found in late '60's (68-71) C6's from FE's and 385 series motors ie; 429-460's
Frank Merkl- Posts : 1524
Re: c6 valve bodies
I'm looking for about 100 of them
Re: c6 valve bodies
Frank, I have one out of a long tailshaft Lincoln trans, might it be the style you're needing?
dirt_worker- Posts : 535
Re: c6 valve bodies
Not the numbers you are looking for ,but if you can use them I have three for free c6 VB,s!
whitefield- Posts : 2244
Re: c6 valve bodies
dirt-worker you'll have to check the casting numbers
Re: c6 valve bodies
whitfield I have lots of the wrong ones
Re: c6 valve bodies
Frank Merkl wrote:whitfield I have lots of the wrong ones
Roger that ! I will check my other trans cores.
Re: c6 valve bodies
Mine has the lower section you're looking for but not the correct upper..
Re: c6 valve bodies
think I may have just bought a 20 , hope I don't get snookered!!!
Re: c6 valve bodies
I have one: filter side C7AP-7A101-DT
other side D2AP-7A092-AA
Not sure how to ship to Canada though...
Iowa 73- Posts : 1
Re: c6 valve bodies
Iowa 73 ,that's not the right one ,the D2ap doesn't work
Re: c6 valve bodies
I've got enough VB's now as I've bought 37 correct ones , But I'm still giving $100 off for a C8AP/C7AP core when you ship it to me on a Transbrake VB order
» C6 valvebody
» OEM p/n valve bodies?
» FRANK M VALVE BODIES
» Looking for two 4 barrel EFI throttle bodies.
» valve cover studs for aluminum valve covers
