Mallory Max-Fire distributor for 351w, or 460 with gear change
For sale one Mallory Max-Fire distributor for a Ford 351w. Part number 1255404. This distributor has a complete hi capacity CD ignition build into it. I used it in my turbocharged 351, but it can be used naturally aspirated as well.. This distributor can be programmed on a computer, you plot your timing curves, max RPM, vacuum advance, and boost retard value. The distributor was gone through by Mallory this last summer, and works great. It comes with all computer communication cables, power and coil wires, 9 volt battery adapter so you can program it with your desk top computer them install in the car, no lap top needed, software disk, new cap and rotor, and instructions with some of my notes. It also has a steel roller cam gear on the distributor. It can also be also be used with no computer by using the dip switches. Everything is explained in the instructions. I would be running it now, but it won't fit with the tunnel ram I am using. Feel free to ask any questions.
Here is a link;
http://www.summitracing.com/parts/MAA-1255404/
$440 new, I am asking $250 shipped to the lower 48. Thanks.
Jess
Here is a link;
Jess
Mustang-junky- Posts : 438
» MSD 351w distributor and 460 dist gear
» Mallory Distributor
» Mallory Distributor & Regulator
» BBF parts for sale. mallory distributor, cloyes timing chain
» 351w roller cam distributor?
