MSD 351w distributor and 460 dist gear
MSD 351w distributor and 460 dist gear Empty MSD 351w distributor and 460 dist gear
Post  nickbay November 6th 2009, 5:19 pm
Years ago I changed out a dist gear and did not drill a new hole, somehow I figured out how to do it and it came out perfectly within spec.
Now I'm wondering should I just cross drill it from the original hole and not worry about it?
I don't have any big cam or oil pump.
I do have lathe/mill, and measuring tools.
These gears have to be within .009 range on the shaft.
I'm not a machinist but I do have machinist friends who could probably help me figure it out if I didn't want to drill a 2nd hole.
I like the idea of putting the pin in the same hole but wonder if it's worth the trouble.
nickbay
nickbay
MSD 351w distributor and 460 dist gear Empty Re: MSD 351w distributor and 460 dist gear
Post  rmcomprandy November 6th 2009, 7:54 pm
To be able to use the same hole and get it right would be shear luck ... after getting the gear in the correct position dimensionally, drill a new hole 90° from the other one on the shaft; a little above or below the first hole.
