foxbody mustang what springs to use with bbf
+8
feetfirst
nuclearcobra
westsideford
514Fox87
D. Sea
AaronS
5pointslow
12 posters
foxbody mustang what springs to use with bbf Empty foxbody mustang what springs to use with bbf
Post  5pointslow October 13th 2009, 8:52 pm
car is set up for sbf and has coilovers front and rear any certain spring rate u guys like up front
thank you
5pointslow
5pointslow
foxbody mustang what springs to use with bbf Empty Re: foxbody mustang what springs to use with bbf
Post  AaronS October 15th 2009, 1:48 pm
I'll tag along on your post. Would like to know also. Currently running 14" 150# with the small block. Thanks.
AaronS
Post  D. Sea October 15th 2009, 3:05 pm
I have 175# coil over springs on my car, most of the drag guys will run the 175# springs on a BBF Aluminum head engine and 175 OR 200# springs on a iron headed BBF combo
D. Sea
D. Sea
Post  5pointslow October 15th 2009, 5:44 pm
realy ive got 175 on there now ...weird alot of guys with sbf are using them
5pointslow
5pointslow
Post  514Fox87 October 15th 2009, 5:54 pm
I'm running 175's on the front and stock springs on the rear. Car runs 10:50's with a 1.41 60ft. Pulls the front wheels about 6-8 inches.
514Fox87
514Fox87
Post  westsideford October 15th 2009, 11:44 pm
Had 175's but switched to 160's.. The change didn't effect the 60 foot.. But then again the car is still a work in progress..
1.5 60 foot with foot brake and cast iron heads.. 3.27 rear gears..
westsideford
westsideford
Post  IDT-572 October 16th 2009, 5:42 pm
I think if you need more lift in the front to aid weight transfer, then put a lighter spring 150# or lower and just adjust your ride hieght back to the original setting by screwing the adjuster nut up until it sit right. Now you have more stored energy to lift the front under launch. I needed to do this on my first engine, but after going to the 557 the 175 seemed fine, actually think limiting the front travel would have helped.
I guess what I am saying is it depends on you combination.
It seems everyone runs the 175# springs with the BBF though.
Post  nuclearcobra October 16th 2009, 6:07 pm
175's here
nuclearcobra
nuclearcobra
Post  5pointslow October 16th 2009, 6:33 pm
racecraft k member with race craft 2 inch drop spindles paid 499$ lol yeah that sucks , i just bought new k member
i see 12 inch and 13 inch control arms why 2 diffrent sizes im using strange front drag brakes
all the help is greatly apppreciated best forum ive been on since and im on nmra ...ect
2 thumbs up to the guy that has it setup
5pointslow
5pointslow
Post  feetfirst October 30th 2009, 10:20 pm
"rule of thumb" front spring weights on a fox...
up to 3000 lbs - 130 lbs
3000 to 3200 - 150 lbs
3200 + - 175 lbs
This is for maximum weight transfer.......if you are going fast and trying to "lose" transfer, go to a heavier spring..
feetfirst
feetfirst
Post  zues-90 November 17th 2009, 2:52 am
isn't 175 pound the stock springs size on a 5.0?? i been searching for front suspension i was looking at this:
http://www.racecraft.com/index.php?main_page=product_info&cPath=272&products_id=88
but then with springs it has a option of 12" 250 lbs or 12" 350lbs springs , is this different for a street car? i plan on making my car fro street, carshows, and joy-riding, what spring size should i be looking at?? my car has stock trim 1990 LX , so 4320 base weight + 270 for 460 then-30 from new k-member
zues-90
zues-90
Post  westsideford November 17th 2009, 3:01 am
I'm using 75lb rear springs
Last edited by westsideford on November 18th 2009, 1:33 am; edited 1 time in total (Reason for editing : Second thought about information I wanted to add)
westsideford
westsideford
Post  zues-90 November 17th 2009, 3:07 am
mines the wrong post??
zues-90
zues-90
Post  bruno November 17th 2009, 8:31 am
your fine Zeus ...i think Les is having a dream ...........
but as far as your question i would think the 175 - 200 would be fine for street use ...the suspension gurus might add there opinion Wink
http://WWW.CKRME.COM
Post  zues-90 November 17th 2009, 3:56 pm
bruno wrote:your fine Zeus ...i think Les is having a dream ...........
thanks, ive been looking at that above suspension k-member package it looks like what i want but only offers 12" 250 or 350 pound springs just go with 250's?? it says its a street package , but im guessing its giving those springs for a 302 in mind not a 460 i might have to compensate for that extra weight compared with their pakage, the extra 270 pounds
zues-90
zues-90
Post  fastford600 November 17th 2009, 7:31 pm
well my set up is 175 in the front and 120 in the rear 1.23 60' all day@5.80's note i am on a 4 line thoe. pig
29.5 x10.5 no w @ 3000 lbs
fastford600
fastford600
Post  westsideford November 18th 2009, 1:36 am
zues-90 wrote:mines the wrong post??
Sorry Bro.. My bad! I wanted to add my rear springs but forgot what the heck I was thinking..
Neighbor came over and started talking..
westsideford
westsideford
Post  westsideford November 18th 2009, 1:38 am
Thanks Nick.. Sorry for the confusion.. 8^)
westsideford
westsideford
Post  bigjohn2007 November 25th 2009, 12:53 am
x2 on the 175
bigjohn2007
bigjohn2007
Post  zues-90 November 25th 2009, 8:16 pm
bigjohn2007 wrote:x2 on the 175
so put the 350 pound spring size on there for street use??
zues-90
zues-90
