help me pick out a set or aftermarket rocker arms for my boat 460
BCOWANWHEELS
guys,
i need a little help picking out the best set of rocker arms and push rods for my ski boat 460 engine. its not a race boat but i ,am just doing a refresh on the engine and seen some wear on the stock rocker assemblys so thought now would be a good time for some roller rockers and c/m pushrods.
heres my engine combo so far
1970 429 thunderjet block & rods
1974 460 lincoln crank (stock stroke)
CJ aluminum heads
cast pistons
offy aluminum low rise and vac secondary holley
dura-spark ign.
armondo 10 qt. oil pan
melling hi-vol. CJ oil pump assy.
all help is appreciated
bob
CJ aluminum heads
cast pistons
dura-spark ign.
bob
BCOWANWHEELS- Posts : 53
Re: help me pick out a set or aftermarket rocker arms for my boat 460
I have run these on mine with .649 lift turning it 6500 rpm in my Ranger with no problems comp cams make some good push rods but most name brand push rods would work
WHICH BRAND/MODEL ROCKERS DID YOU USE ?
BCOWANWHEELS wrote:WHICH BRAND/MODEL ROCKERS DID YOU USE ?
Sorry about that forgot to put the brand down was late when I posted brain was half asleep.Here is the rocker I have.
http://www.summitracing.com/parts/csp-s4005/overview/
I ran the trick flow push rod when I was running this setup and all of it will be going back in the engine when I pull the heads and go back to the dove heads on my 460 when it goes in my 69 f100
NO PROBLEM HARLAN SHARP MAKE SOME GOOD STUFF,THANKS
I use the Comp Ultra Gold Rockers and Comp Push Rods with No Problems
OldRed70- Posts : 155
no doubt crower is the best but seeings i,am not running big spring pressures i think the harlan shrp will be fine. thanks though
bob
bob
Just kinda curious ... what type stock rockers did you have on CJ ALUMINUM heads...?
There are several types and early Cleveland rockers or Boss 302's were used quite a bit years ago...
I would use the FRPP offerings.
I,VE NEVER RUN THE FRPP CJ HEADS THERE N.O.S. I TOOK THE DOVE -C'S OFF. I MAINLY WANTED TO TAKE SOME WEIGHT OFF THE BACK OF MY BOAT.
Crane gold or Ford Racing (same piece) for best, easiest geometry for the money IMO!
Bret
Bret
Bret Powell- Posts : 133
I,LL LOOK INTO BOTH OF THEM, THANKS
