rocker arms
rocker arms
I was just shopping for future reasons and was looking at the COMP Cams 1630-16 - COMP Cams Ultra Pro Magnum Rocker Arms and noticed some thing that is of concern and you guys may have seem this in the past/present. Maximum Spring Diameter (in):1.550 in? So I run anything from 1.625-1.640 will this be a problem? Or is there some thing else i should be looking at. I been running some old Lunati's and was looking for replacements. Also is there any place that rates the rocker ability verse spring rate?
Ace
Ace
powerstrokeace- Posts : 1496
Re: rocker arms
1860-16 was what i ment. i just can't type/read at times. Noticed the Trick Flow and Crane offer ones that have 1.630 dia. spring clearance
Ace
Ace
Re: rocker arms
I have the 1830-16 and they clear the 1.640 springs just fine.
460pulling- Posts : 249
