Deck height
FORDMUD
bigjohn2007
Deck height
How do u get deck height right when building engine? I have block bored 4.420 and want to stroke it.Already have crank,rods,and pistons.Bought the block already bored would like build it myself as i have never done so.Was wondering about deck height so i get it right the first time. thanks john
bigjohn2007- BBF CONTRIBUTOR
Re: Deck height
Mock it up and measure. Go from there.
FORDMUD- Posts : 290
Re: Deck height
As previously said, mock it up, the best way to do it is, put a rod and piston in each corner of the block, 1,4,5,&8 and check each corner, as some have found the deck is sometimes not square to the crankshaft centerline. Some will use 4 piston/rods for this and some will use the same rod/piston in all 4 corners.
racnrick- Posts : 462
Re: Deck height
thanks so i dont have to put rings on right
Re: Deck height
bigjohn2007 wrote:thanks so i dont have to put rings on right
No you don't have to have the rings on alot easier without the rings or I didn't when I check mine
Re: Deck height
You don't have to use the rings, but I use masking tape around the ring lands, to make sure the pistons stay fairly square in the bores...
ThndrChkn- Posts : 2216
Re: Deck height
is the pistons most time lower than block and if so what the goal deck height
Re: Deck height
Your desired deck height will depend on your overall goals ... I try and get mi-ne to - .005... (.005 in the hole) If it's a street app, I'll leave it a little more in the hole to help keep compression lower, though it may affect your quench a little...
Re: Deck height
Well I'll be dam i learning a little here.
» BBF Deck height
» got some deck height issues
» piston to deck height
» ok what block? 11.7 or 12" deck height
» A460 deck height
» A460 deck height
