Injector brand
Injector brand
What is a good brand of injectors to use or are they mostly the same. I have a Holley HPefi unit for my 460, converted victor jr manifold. I looked at the Holley ones as well as I see TFS has a TFX line. They all look the same on the outside so I am assuming this is where experience comes in.
I am thinking 48-55 lb. My app is a 460 ci, TFS streets, comp street roller, vic jr intake, 2" headers in my 56 Ford with a Lentech AOD.
jasonf- BBF CONTRIBUTOR
Re: Injector brand
They look the same because most of them are. They are rebranded Bosch. In that size range you really can't go wrong with any of them.
whatbumper- Posts : 3024
Re: Injector brand
Thanks for the reply. How much can you oversize your injectors. If you need 48's can you use a 60 lb injector and have room for expansion later on?
Re: Injector brand
jasonf wrote:Thanks for the reply. How much can you oversize your injectors. If you need 48's can you use a 60 lb injector and have room for expansion later on?
You can do that. You will just have to trim the tables and possibly sacrifice a little idle quality but the idle may not be effected as much on the smaller injectors like that. When we went from 160's to 225's it did a little.
» Injector Height
» Blue Thunder Tunnel Ram with alcohol injection and nitrous
» Injector size
» ef1 521 more questions? this will blow your mind!
» 69 Mocking it up, BBF 8-71 BAU injector
» Injector size
