Injector size
Injector size Empty Injector size
Post  mountainsurfer June 19th 2013, 10:49 am
Wondering if anyone has been down this route before. I'm in the middle of putting the final touches on a stroked 460 out to 502. Have converted to MAF many miles ago and works great. The question is.....stock fuel injectors being 24lb/hr, what size would be recommended? Many choices out there. Maybe the stock injectors will work? Staying with stock CR and only mild Erson RV cam. Looking to be a tow unit and not high HP.
Thanks.
mountainsurfer
Injector size Empty Re: Injector size
Post  rmcomprandy June 19th 2013, 11:59 am
Yaking you build into consideration:
If you have a sequential injection system then run 42 lb/hr injectors.
Batch fire injection can run 30 lb/hr.
Either way, you will need computer modification capability.
