Q's about 351w?
LivermoreDave
whitefield
stanggt
Q's about 351w? Empty Q's about 351w?
Post  stanggt March 20th 2013, 11:33 am
building a 420 stroker with 11.14 compression, AFR220 renegade heads, custom roller cam from Bullit Cams, some street driving but at track will spray a 200hp NOS shot plate system every now and then. What head gaskets should I run and also what motor mounts should I use, solid or poly?
stanggt
stanggt
Q's about 351w? Empty Re: Q's about 351w?
Post  whitefield March 20th 2013, 11:49 am
stanggt wrote:building a 420 stroker with 11.14 compression, AFR220 renegade heads, custom roller cam from Bullit Cams, some street driving but at track will spray a 200hp NOS shot plate system every now and then. What head gaskets should I run and also what motor mounts should I use, solid or poly?
Run the Poly with the torque limiter!
http://www.summitracing.com/parts/cee-4010/overview/
whitefield
whitefield
Post  LivermoreDave March 20th 2013, 12:45 pm
The choice of head gasket design may rely on the cylinder head and block mating surface finish. The Nitrous may need a steel layered gasket, although block finish will dictate or have bearing on your decision. Solid motor mounts.
Dave.
LivermoreDave
Post  67mustang March 20th 2013, 1:21 pm
Cometics and solid mounts
67mustang
67mustang
Post  whitefield March 20th 2013, 1:36 pm
67mustang wrote:Cometics and solid mounts
I agree with head gasket choice ,but if your going to drive it on the street it gets pretty annoying with the viberation from the solid mounts. The mounts are what ever you can tolerate.
whitefield
whitefield
Post  stanggt March 20th 2013, 7:10 pm
LivermoreDave wrote:The choice of head gasket design may rely on the cylinder head and block mating surface finish. The Nitrous may need a steel layered gasket, although block finish will dictate or have bearing on your decision. Solid motor mounts.
Dave.
the block has a fresh cut deck at zero. I was leaning toward the cometics also. And if I use solid motormounts, would I use a rubber or poly mount on trans?
stanggt
stanggt
Post  LivermoreDave March 20th 2013, 7:41 pm
On the street, if you haven't created a rigid frame connection between the front and back it may be best to rubber the transmission. Ask your machinist about the deck's finish.
Dave.
LivermoreDave
Post  Maxx Levell March 20th 2013, 9:28 pm
On mine, I took the stock motor mounts and drilled through them vertically. I then ran two grade 8 5/8" bolts through them and bolted them snug. That way, the factory rubber isolator still absorbs the vibration, but I don't have to worry about splitting the factory mounts. It's worked great. Best of all, it's relatively cheap lol.
Maxx Levell
Maxx Levell
Post  Mark Miller March 21st 2013, 1:19 am
Maxx Levell wrote:On mine, I took the stock motor mounts and drilled through them vertically. I then ran two grade 8 5/8" bolts through them and bolted them snug. That way, the factory rubber isolator still absorbs the vibration, but I don't have to worry about splitting the factory mounts. It's worked great. Best of all, it's relatively cheap lol.
Is that a Maverick in you avatar,if it is you have any pictures or specs on the car?
Thanks Mark.
Post  Mustang-junky March 21st 2013, 8:18 pm
Convertible 5.0 motor mounts come like this already, plus they lower the motor a bit, and last time I checked they were cheaper than standard 5.0 mounts.
Jess
Mustang-junky
Mustang-junky
