Need help on build
Need help on build
Wanting some help on parts combo going to build a 532 for my maverick got a victor 4150 and 850dp mostly street and strip what cam and lifts talked to ande about a forged crank and rod assembly any help would be great looking to make at lest 600 hrs
robbie mav grabber- Posts : 34
Re: Need help on build
Need more info.Heads,are they ported? etc.
Going to run kaase super cobra jet heads the car has nine inch 411 Detroit locker going to be c6 with a stall don't know what stall to run Fulton competition is going to put engine together
No one has any suggestions on cam and lifts or stall for good street engine solid roller or what or does any one have a set of used heads or parts forsale thanks
I'm not the one to be giving Cam spec's,but on a engine that big,I would think a 950 hp.carb would be the minimum. And on a converter w/3 speed and mostly on the street.I wouldn't go any bigger than a 2800/3000 stall. jmo
Have Fulton design a cam for it if they are building it
John Myrick- BBF CONTRIBUTOR
Thanks what heads do y'all think would be best super cobra jets or trick flow 290 would p51 be to much for the street ill ask Gene Fulton if they can grind a hyd roller
Thanks big block falcon talked to Blake Cartwright today about a custom grind roller cam
robbie mav grabber wrote:Thanks big block falcon talked to Blake Cartwright today about a custom grind roller cam
Yep,he will get you fixed right up.
» E4OD build reccomendations for a 79 f150... first transmission build, no ideah what I'm doing
» No rules BBF nitrous build - Let's build it
» 580 build P-51 build ideas
