Thanks to 429-460 forum. ET improvement.
70FB
I never realized all ignition boxes were that much different in timing. I had 5 runs on the car with the new motor with a best of 9.81. Checked the timing last week after reading the MSD question thread and double checked mine. It was supposed to be at 38 degrees and found it at 34 degrees. Changed it and ran this weekend. 9.77 first run and 9.79 second run. I also made an airpan of aluminum to seal the carb to the cowl after doing the yarn test on the back of the cowl.That may have contributed to it also. I will test later without the airpan as I didn't have time yesterday. I was trying to slow it down to 10.00 class at VMP on the 30th. I will let all know when I test it to see if it was the airpan or timing. Bet it was the timing though. Thanks to all on this forum and the people that support it!!!!
70FB- BBF CONTRIBUTOR
Re: Thanks to 429-460 forum. ET improvement.
also make note of the air/weather/ track temps as it will effect performance also.
congrats thats some great improvements
70FB wrote:I never realized all ignition boxes were that much different in timing. I had 5 runs on the car with the new motor with a best of 9.81. Checked the timing last week after reading the MSD question thread and double checked mine. It was supposed to be at 38 degrees and found it at 34 degrees. Changed it and ran this weekend. 9.77 first run and 9.79 second run. I also made an airpan of aluminum to seal the carb to the cowl after doing the yarn test on the back of the cowl.That may have contributed to it also. I will test later without the airpan as I didn't have time yesterday. I was trying to slow it down to 10.00 class at VMP on the 30th. I will let all know when I test it to see if it was the airpan or timing. Bet it was the timing though. Thanks to all on this forum and the people that support it!!!!
Should have slowed down going from 34* to 38*
I didn't fool with checking the DA but air temp was 54 and 5 mph head wind.. Nothing on the track temp. Right now I'm using the "Jeg's logbook" which has some room for improvement. May make a spreadsheet to have my own stuff that I need.richter69 wrote:also make note of the air/weather/ track temps as it will effect performance also.
May have come from that airpan..??...pulling from the higfh pressure area at the base of the windshield.bbf-falcon wrote:70FB wrote:I never realized all ignition boxes were that much different in timing. I had 5 runs on the car with the new motor with a best of 9.81. Checked the timing last week after reading the MSD question thread and double checked mine. It was supposed to be at 38 degrees and found it at 34 degrees. Changed it and ran this weekend. 9.77 first run and 9.79 second run. I also made an airpan of aluminum to seal the carb to the cowl after doing the yarn test on the back of the cowl.That may have contributed to it also. I will test later without the airpan as I didn't have time yesterday. I was trying to slow it down to 10.00 class at VMP on the 30th. I will let all know when I test it to see if it was the airpan or timing. Bet it was the timing though. Thanks to all on this forum and the people that support it!!!!
You mentioned a yarn test .What the heck is that?
Dave C.- Posts : 1268
With a cowl induction hood. Tape some yarn to the top of the cowl hanging down to the cowl. When you go down the track look to see which way its going. If its sucking in towards the carb...the engine is getting good clean air from the high pressure area at the bottom of the windshield......If its blowing towards the windshield...you could have a reverse pressure actually pulling the air from the carb. The carb would be sucking the hot air under the hood and have a negative flow going to it.
Dave C. wrote:You mentioned a yarn test .What the heck is that?
Thats what I wanted to know !
whitefield- Posts : 2244
70FB wrote:With a cowl induction hood. Tape some yarn to the top of the cowl hanging down to the cowl. When you go down the track look to see which way its going. If its sucking in towards the carb...the engine is getting good clean air from the high pressure area at the bottom of the windshield......If its blowing towards the windshield...you could have a reverse pressure actually pulling the air from the carb. The carb would be sucking the hot air under the hood and have a negative flow going to it.
Some good info!
sorry for the double post
got any pics of your airpan ?
Take me a little while to load them up.whitefield wrote:got any pics of your airpan ?
70FB wrote:Take me a little while to load them up.whitefield wrote:got any pics of your airpan ?
I undwestand ! I still can't load pics
I used a "grip edge seal" from Mcmaster-carr to seal between the aluminum and hood. Hood is a 4-3/4" cowl. The seal basically has a 3/4" grip on bottom and a 1" hose on top for the seal. Worked perfect.
70FB wrote: I used a "grip edge seal" from Mcmaster-carr to seal between the aluminum and hood. Hood is a 4-3/4" cowl. The seal basically has a 3/4" grip on bottom and a 1" hose on top for the seal. Worked perfect.
Very good info and thanks for the pics . How thick was the Aluminium that you made the pan out of ?
.060 from a local metal yard. scrap piece about 3'X5' was about 35$. Total invested was maybe $50 bucks and 4 hours worth of time. Have some carbon fiber ready to try to duplicate. The key word is "TRY"!!!! hahaha
Dave C. wrote:I want one.
Like the pic in your Avatar Better !
70FB wrote:.060 from a local metal yard. scrap piece about 3'X5' was about 35$. Total invested was maybe $50 bucks and 4 hours worth of time. Have some carbon fiber ready to try to duplicate. The key word is "TRY"!!!! hahaha
I am going to try and make me one this week! I am by no means a fabricator !
I don't have a metal brake. I have a bench with a 3/4" plywood top. I unsrewed it and put the metal in there..then screwed it back down and used a long 2x4 to bend it. Just take your time with it. I will update here with the carbon fiber trial. May be a couple days though.
I can use Jons trailer door. Think it,ll work on a forward facing scoop?
Maybe thats what happened to mine in the past. Its bent on one side. hahahaDave C. wrote:I can use Jons trailer door. Think it,ll work on a forward facing scoop?
I bent my door panels on the trailer door, I got that tip from ol Mike D......
» valve improvement.?
» Shop Electrical Improvement
» 460 powered RV - Gas Mileage and power improvement
» Truck for sale
» NEW TO THE FORUM
» Truck for sale
» NEW TO THE FORUM
