new to NOS ! ?
+8
stanggt
Barney
61coon
Dave C.
whitefield
12 posters
Page 1 of 3 1, 2, 3  Next
new to NOS ! ? Empty new to NOS ! ?
Post  whitefield March 24th 2013, 5:18 pm
I am use to running pump gas N/A street motors so I am going to ask some questions about to different engine combos.
1st is a sbf 10.5:1 engine with good parts through out runnin a stock 74 351w block.
2nd is a 13.5:1 engine mostly stock parts but all are race prepped and ballanced.
Will be running Msd 6al ignition and no mor than 150 hp of NOs.
Do I need a dedicated fuel pump and supply line for both cars ?
On the pump gas sbf what octane fuel should be run when spraying.
What plate system for an entry level kit do you recomend ?
whitefield
whitefield
new to NOS ! ? Empty Re: new to NOS ! ?
Post  Dave C. March 24th 2013, 5:35 pm
Jon posted an inexpensive system a while back for a guy...I'll try to find it.
Dave C.
Post  whitefield March 25th 2013, 9:18 am
Dave C. wrote:Jon posted an inexpensive system a while back for a guy...I'll try to find it.
Thanks Dave !
whitefield
whitefield
Post  IDT-572 March 25th 2013, 2:29 pm
Mike it will depend on your compression and what material your heads are made of and the specs on your camshaft along with some other items.
How good a tune you have and how close to the line are you on being able to run 93 octane.
9 to 1 aluminum heads with good quench and no sharp edges in the combustion chamber area 150 shot with a pump big enough to supply the full at wfo will be fine.
10 to 1 cast iron heads .035 quench and 150 shot may or may not work on 93 octane. More than likely not
You can test the system with both needles open (carb) and flowing through the nos fuel jet to see if it will maintain fuel pressure at both regulators at the setting you need.
Post  richter69 March 25th 2013, 6:51 pm
bang for the buck
http://inductionsolutions.com/shop/nitrous-accessoriescomponents/performer-rpm-nitrous-kit/
ran this kit up to the max jet on Jacobys 383 with a little more spread in the jet w no issues, and the same kit on my 306 but w a bigshot style plate and a 15 jet spread...... made it haul ass.
Post  Dave C. March 25th 2013, 7:02 pm
That's the one !!! Very Happy
Dave C.
Post  richter69 March 25th 2013, 7:16 pm
go measure tires......
Post  whitefield March 25th 2013, 9:12 pm
On the small block ride it is 10.5:1 and run 93 N/A ,but I figure with 150 hp on a plate system I would need to run 110 octane fuel. The cam thats in it now isn't the Jay Allen cam it is a comp custom grind. The new cam doesn't have as much spread in duration as the old cam did! Shocked
On the Big block in the Fairlane it is a cast Iron ported 13.5:1 motor with a small hyd flat tappet cam. I plan on running 150 hp on it too.
whitefield
whitefield
Post  whitefield April 8th 2013, 4:10 pm
To go along with my Nos questions, which one of these cams would work the best. I am not going to buy a new cam because I am saving that money for a new engine combo. Thanks
First is a solid roller
intake .690 exhaust .691
duration@.050 261 intake 268 exhaust
lsa 108
Second is a solid roller
Intake .690 exhaust is .672
duration @.050 is 255 intake 272 exhaust
lsa 107
whitefield
whitefield
Post  richter69 April 8th 2013, 4:28 pm
first one
Post  IDT-572 April 8th 2013, 4:53 pm
richter69 wrote:first one
X2
Post  61coon April 8th 2013, 5:00 pm
X2
That's what I was gonna say
61coon
61coon
Post  whitefield April 9th 2013, 11:15 pm
I will be talking to my Nos Guy this weekend! Razz
whitefield
whitefield
Post  whitefield April 9th 2013, 11:20 pm
Was also thinking about switching rear gears from 4.11 to 3.73 ! what do you think ?
whitefield
whitefield
Post  61coon April 9th 2013, 11:35 pm
I'd prolly stay with the 4.11's.
61coon
61coon
Post  whatbumper April 10th 2013, 7:49 am
I would put the 3.73's if you are going to spray more but for a little 150 shot I would stay 4.11 unless you run out of gear at the big end.
Post  Barney April 10th 2013, 9:19 am
whitefield wrote:Was also thinking about switching rear gears from 4.11 to 3.73 ! what do you think ?
1/4 or 1/8?
Barney
Barney
Post  richter69 April 10th 2013, 10:57 am
leave the 4.11 if its 1/8th mile
Post  whitefield April 10th 2013, 11:03 am
1/4 or 1/8?
Mostly 1/8 but will be running in the 1/4 in the spring and fall . Twice a year 1/4 mile passes and about 6 passes at each race more if I do well .
whitefield
whitefield
Post  Barney April 11th 2013, 4:02 pm
I would say IF you mostly run 1/8 and IF you don't plan to spray that much then leave the 4.10 , but your quarter will slow down more in the quarter running out of rpm than your eighth will be affected running a gear that is slightly too tall. Spray makes tons of torque and that little of a gear change will have little effect on your short times.
Barney
Barney
Post  whitefield April 11th 2013, 4:10 pm
Barney wrote:I would say IF you mostly run 1/8 and IF you don't plan to spray that much then leave the 4.10 , but your quarter will slow down more in the quarter running out of rpm than your eighth will be affected running a gear that is slightly too tall. Spray makes tons of torque and that little of a gear change will have little effect on your short times.
Thanks and as I go along I may have some more questions .
whitefield
whitefield
Post  Barney April 11th 2013, 8:36 pm
Anytime.
Barney
Barney
Post  whatbumper April 11th 2013, 9:20 pm
Think of it this way. you need to get to the 1/8th as fast as possible. you need the best 60ft and best 330. 1/8th mile and 1/4 makes no difference to me. in MY experience with the type of car we are talking about here the faster to the 1/8th, the faster to the 1/4 regardless. set it up for the 1/8 mile and if you run the 1/4 awesome. your rpm increase in the extra little bit wont make that much of a difference. if you decided to spray more go with the 3.73s definitively. if it's all motor or the baby shot then stick with the 4.10's
Post  whitefield April 11th 2013, 9:31 pm
whatbumper wrote:Think of it this way. you need to get to the 1/8th as fast as possible. you need the best 60ft and best 330. 1/8th mile and 1/4 makes no difference to me. in MY experience with the type of car we are talking about here the faster to the 1/8th, the faster to the 1/4 regardless. set it up for the 1/8 mile and if you run the 1/4 awesome. your rpm increase in the extra little bit wont make that much of a difference. if you decided to spray more go with the 3.73s definitively. if it's all motor or the baby shot then stick with the 4.10's
150hp shot is what I plan on putting on it ! Who knows may go more after I get use to it and all of the bugs worked out.
whitefield
whitefield
Post  stanggt April 19th 2013, 10:53 pm
subscribed Twisted Evil post results when you get them please.
stanggt
stanggt
